Go Back   RC-Monster Forums > Questions and Answers > Pre Sales Questions
Upgrade brushless motor ?
RCHabit
Upgrade brushless motor ? - 11.26.2007, 03:12 PM
hello,
I purchased my set up from Mike,
it is
8XL
Mamba max ESC
I also run 2 7.4 8000mah lipo for 14.8V
Proline big Joe tires
I want to upgrade the motor for a little more speed, What does the RC monster have? I use the truck (e-maxx) on grass and hardpacked dirt roads.
Thanks in advance
11.26.2007, 03:56 PM
More speed than an 8XL can provide? I would say take a look at your gearing first, and see if there is the possibilty to gear up without overheating the motor &/or esc too much. The Bigjoe tires will slow the setup you have down, and also force it to work harder since they are very heavy- better off with some lighter bowties or mashers for those 40 series rims. Checkout BrianG's calculator for more gearing/motor options: CLICKY
aqwut
Brushless Heavy Weight....
aqwut's Avatar
11.27.2007, 10:02 AM
Originally Posted by RCHabit View Post
hello,
it is
8XL
Mamba max ESC
Thanks in advance
That should go Plenty Fast.... What gearing are you using? and is the Motor or ESC warm/hot?
I have a 7XL in one of my Maxx truck with 4S as well...
The Power of BRUSHLESS!!!!!
1HP (electric) = 746 Watts.
Everything is brushless!!
neweuser
neweuser's Avatar
11.27.2007, 03:52 PM
I would say on an 8xl, he should be able to gear up some. Otherwise, go with a 7xl...if you are running 4s, I would suggest 7xl....
RCHabit
11.27.2007, 08:04 PM
I'm go to do some fine tunning and then let you know,
I will change my tires for some lighter ones and gear it up and see.
Thanks
Superbasher
Superbasher's Avatar
11.29.2007, 04:08 PM
Another thing that you could do (if you have the money) is upgrade the ESC - That way you could run a higher cell count.
  Send a message via MSN to Superbasher
