Few questions on E-Revo Conversion
chumanji
Few questions on E-Revo Conversion - 12.04.2007, 03:37 PM
What do you guys think about the Tekno conversion kit. Opinions pls.
Are there any big difference between the 8xl and 9xl motor?
If I use the Tekno kit, do I need to change any gear ratio or use the stock clutch bell.
Do I need to lock the 2nd speed? What other mods do I need to do?
12.04.2007, 03:58 PM
The 8xl will run hotter - 9XL on 4s is a good balance IMO...
I don't have the tekno kit so can't comment on the other bits - Best of luck with the build...
Jeremy1976
12.04.2007, 06:35 PM
You can stick with the same gearing you used on the Revo with the same trans. That is what it was designed for. However with the extra power/torque of BL you may want to gear it a little taller. Yes you can and will be using the stock clutchbell. No you do not need to lock 2nd if you want to have a 2 speed trans. I have the Tekno kit and think it is great. I am also going to be using the stock Revo 2 speed trans. I do however have the FOC (forward only control) installed in it. I am also going to be running 16/36 gearing to start and then try a 18/36.
JB3231
JB3231's Avatar
12.04.2007, 10:13 PM
I' running the FOC locked into 2nd with a 9XL and 4s. Current gearing is 20/38 and it's pretty quick. I just ordered a 24/38 setup for more speed.
I think something around 22/38 would be just about right. I'm running around a cul-de-sac on concrete with max size tires so I need taller gearing than most probably.
I must admit the Revo 3.3 chassis is in another league compared to the Emaxx chassis I just took apart.
Mine:
2007 Grizzly 700 EPS EFI
Sons:
BL E-Maxx
4S MA 4000 Lipo/MM ESC
Feigao 9XL 22/54 gearing
Gmaxx single speed
Brushless Revo under construction
