Grind a Neu...
steve050773
Grind a Neu... - 12.13.2007, 06:27 PM
You guys grind a flat spot on the Neu's for your pinion? Or does 5mm give enough grip surface for the set screw...
mkrusedc
NeuMaxx
mkrusedc's Avatar
12.13.2007, 06:30 PM
Everybody here says grind it. I have not yet and so far no slipping.
cemetery gates
12.13.2007, 06:31 PM
I ground a flat spot on mine, you really need it given the amount of torque these motors produce. I also use some locktite on the setscrew. If you do those two things you should rarely have a pinion come loose.
Bye
steve050773
12.13.2007, 06:33 PM
Yeah I know its what I should do... but I hate to touch a dremel to such a purty motor...
Its a 1506 so I might try and get away without it.... at least until a $15 pinion goes bye
tallyram
tallyram's Avatar
12.13.2007, 06:40 PM
i never grind them, one less thing that can damage the motor! i soaked my pinions in denatured alcohol to remove all residues and once they dried picked one added small amount of locktite and haven't spun one yet! i change pinions frequently.
luxury!
  Send a message via AIM to tallyram
austinmaxx
12.13.2007, 07:32 PM
If you don't grind the flat spot and your pinion slips will anything bad happen have a 1515/1y I am putting together and it scares me to grind on my 300buck motor
aqwut
Brushless Heavy Weight....
aqwut's Avatar
12.13.2007, 10:06 PM
you could possible have a nice circular ring around your shaft...just tape up the holes and file it... it's easy.. takes 30 seconds...
The Power of BRUSHLESS!!!!!
1HP (electric) = 746 Watts.
Everything is brushless!!
ClodMaxx
hold my beer... watch this...
ClodMaxx's Avatar
12.13.2007, 10:44 PM
steve knows how to do it - he did a great job on the lehner i have.... haven't lost a pinion off of her yet.
Eflite Blade 400 heli on 3s
2FastSS4U
RCM Brushless Savage
2FastSS4U's Avatar
12.13.2007, 10:47 PM
I lost 2 pinions on my 1515/2.5D before I finally broke down and ground a flat spot on my shaft, I too was scared because it's a pricey motor but it turned out great and haven't had a single problem since. Also loc-tite usually has a 24hr curing time so be sure to give it enough time to set before you bash on it Good luck.
The wisest mind has something yet to learn. (George Santayana)
Patrick
Patrick's Avatar
12.14.2007, 12:10 AM
I ground the shaft on mine. I never use loctite, and the pinion doesn't come loose. I don't grind the last 1mm or 2, so if the pinion does start to come loose it shouldn't be able to slide past the ridge at the end of the shaft.
12.14.2007, 03:35 AM
I ground a flat spot on mine too, but I did have to also use lock-tite to keep the stupid grub screw from coming out. But that may be because I'm using a metal pinion on a metal spur.
Aragon
12.14.2007, 05:06 AM
I'm another flat spot grinder and loctiter. :D
nl12
nl12's Avatar
12.14.2007, 08:37 AM
I wouldnt run it without the flatspot
Matthew_Armeni
Matthew_Armeni's Avatar
12.14.2007, 12:43 PM
I don't understand why they just don't come with a flat spot from the factory. It would be easier on us, and then there wouldn't be any warranty issues to deal with. How much more would it cost them?
@ nl12- You're in Pensacola? I was stationed there about 4 years ago. Do they still have the red clay off-road track by the mall? I know they got a nice asphalt on-road track setup as I was leaving. I have some pics of us running out there, I'll try to track them down.
  Send a message via AIM to Matthew_Armeni
dadgummit
12.14.2007, 01:00 PM
I ground flat spots on both of my Neu's but I don't use locktite anymore. Every time I use locktite on grub screws I end up breaking off the tip of the hex driver in the grub, It is a total pain using a Dremel cut off wheel to remove the pinion gear.
Cen ME16 Sidewinder 5700
CRT.5 MM + 1509 1y
FLM Rustler MM & 7L
E-Maxx Hv maxx 6.5 + FLM E-Maxx
Stock E-Maxx for friends to bash
8ight-t 1515 1y in the works
What's Next?
