Stampede Needed Love
Talking Stampede Needed Love - 12.18.2007, 11:43 PM
Hi,
I've spent the last 4 months giving lots of love to my revo and working on new conversions Mugen MBX5 RSX, Jammin X1-CR, CRT .5 so I figured it was about time I take a look at the old pede where it all started for me.
Anyway there wasn't much left of the old pede once i started
Out with the old...
In with the new...
CF Chassis - With under chassis Battery tray
FLM Extended Arms Front & Rear
FLM C-Hubs
FLM Towers
Stock Trans with Steel Rim Diff and Top gear (FLM I found too heavy for me)
Nitro Front End
RPM Rear Bearing Carriers
CVD's
RPM bumper
Spektrum / MM / 4600 / 3s 5000Mah Maxamps
Z590 Servo - Need to get something faster...
Cheers!
12.19.2007, 12:03 AM
What body is that? It sooo ugly, its cool!!!!
glassdoctor
TEAM FUSION
glassdoctor's Avatar
12.19.2007, 12:18 AM
I don't think that comes from anything r/c related... aka not supposed to be a body. lol
Jammin CRT MM/Neu 1515 1700kv
Losi 8IGHT MM/Neu 1512 1900kv
Kyosho 777
T4 MM 5700
B4 LRP
XX4 MM 7700
12.19.2007, 12:37 AM
That my friends is car of StampedeProject! It is a lowes mini paint tray!
Costs all of $4 and 30 mins with a dremel and are light but solid! The amount of abuse they take is incredible.
I gave up on regular bodied after spending $25 on a traxxas body then flipping on my first run at about 40MPH - trashed the body!
I thought what is the point... These work great and are cool in there own way! :)
MTBikerTim
Yip Yip Yip...
MTBikerTim's Avatar
12.19.2007, 12:47 AM
Are they the stock shock? My friend and I are going to need new shocks very soon. The Stampede I have is for the kid and I though stock would do but yesterday he had a WOT head on with the drain on the side of the road and the rear shock popped off and went down the drain. Why the rear shock popped off in a head on I do not know but it was a pain retrieving it from the drain. My mate just keeps blowing the tops off on big jumps.
12.19.2007, 07:35 AM
That is a known fault with the plastic caps - They flex too much and can break the top of the shick off - You can rebuild them with the aliminium caps and plumbers tape which stops most issues.
This pede has Traxxas Aliminium big Bores all round so the only issue I get is bent shafts...
I popped in some stiffer blue springs in the back last night too after the photo was taken...
MTBikerTim
Yip Yip Yip...
MTBikerTim's Avatar
12.19.2007, 04:52 PM
Thanks. I might give those a try. And that idea with the fuel tubing would probably work too. I doubt it's worth fixing the stock ones now as they have popped so many times the threads not looking too good.
Excellent Body!!!!
stampedeproject
stampedeproject's Avatar
Excellent Body!!!! - 12.24.2007, 03:10 PM
Glad you joined the club! The best body you can ever put on a bashing Stampede period. Mine is still going strong.
12.19.2007, 02:18 PM
You can also add some fuel line on the shock shaft to absorb some of the impact
12.24.2007, 05:16 PM
i'm on my third and it has a terminal crack but would never go back to a stock boy on my pede!
Thank you for the great tip!
