Connector between batt and ESC??
david lamontagn
Connector between batt and ESC?? - 01.05.2008, 01:23 AM
Wich type of connector do you use on the batterie side (between the batterie and controller??
Dean?
bullet type (wich size?)
On mine, i use bullet 5.5mm, but it's a pain to disconnect
jhautz
jhautz's Avatar
01.05.2008, 01:26 AM
Ive been using deans for a long time. Never had any problems or saw a reason to switch.
to make it...
or break it...
Silent...But Deadly
MetalMan
MetalMan's Avatar
01.05.2008, 01:36 AM
Deans here too, for at least 4 years.
sikeston34m
sikeston34m's Avatar
01.05.2008, 01:50 AM
Ultra Deans here also. They do handle alot of current with no problems.
I have been looking at the new Traxxas Connectors though.
jhautz
jhautz's Avatar
01.05.2008, 01:55 AM
I thought about the traxxas for about a minute too. Then the reality of changing every connector I had on every model and every battery set in. All of that soldering and money for connectors made my skin crawl...
to make it...
or break it...
Silent...But Deadly
01.05.2008, 01:59 AM
Deans all the way. I have a feeling that they will last longer, the traxxas rely on the plastic flexing to hold them together tightly, at least the deans have the little springy metal piece (sorry about the overly scientific term) you can shape to suit.
jnev
jnev's Avatar
01.05.2008, 04:58 AM
Haha. Thats too funny.
I also use deans on all my stuff between the ESC and battery. But I use 5.5mm bullet connectors between the motor and ESC.
Patrick
Patrick's Avatar
Deans for me.
BP-Revo
BMW M Power!
BP-Revo's Avatar
01.05.2008, 02:10 AM
Have always run Deans except the first month I had my E-Maxx (which was my first electric truck).
aalzuhair
01.05.2008, 03:35 AM
Same here ... Ultra Deans
teknorc
01.05.2008, 03:44 AM
I'm running the Traxxas connectors now. I switched from the Deans. I was tired of pulling so hard on the Deans without a good place to grab hold of. So far I really like the Traxxas connectors. It was faster than I thought to switch over and no heat shrinking is required. A whole fleet of batteries and speed controls (6-8 batteries, 4 ESC's, and 2 chargers) took about 1-1.5 hours total.
A couple minor issues:
1. If you have to remove them for any reason it's near impossible to do it without destroying the connector housing.
2. If you don't pay attention to the 'solder line' it can be difficult to insert the connectors into the housing. I just solder them real good and clean up the joint with a Dremel until it's at the solder line and I haven't had any trouble since.
I've noticed no difference in power or heat, you'd need equipment to measure that.
Tekno RC - Performance Parts
phildogg
phildogg's Avatar
01.05.2008, 09:45 AM
I use deans also,have used the Traxxas connectors also. Like soldering them better though.
phil
Slash 4x4 163mph
drc rail 150 mph
phildogg6@yahoo.com
my youtube channel
knotted
01.05.2008, 09:54 AM
Dean's rule the roost.
david lamontagn
01.05.2008, 09:58 AM
Wow!! Deans is very popular, i've always use Deans before, but this time i want to give a try to the 5.5 bullet. The only down side of this 5.5 that i can see first, is that's a pain to disconect, and realy hard to solder, because the connector have a fuc... hole in it's side and it's realy difficult to fill the conector with solder because i loose it by the hole.
I use 5.5 bullet between the motor and ESC too.
sikeston34m
01.05.2008, 11:09 AM
Just be very careful since the color of your leads is your only means of "Reverse Polarity Protection". You could go "male-female" on one side, and then do the same on the other side. This way they can't be plugged in backwards.
When I solder Bullet connectors, I always tin the wire first with alot of solder. Once it's tinned all the way around, remove the heat and continue to lay solder on it. Create a "bulb" of solder there.
Then I insert the connector into a clamp on a "helping hands" and fill the connector to the bottom edge of the hole you mentioned. A little always runs out that I have to clean up when I put the wire in.
With heat applied to the connector, the tinned wire will heat up and slide right in.
On the larger connectors, I've noticed they don't fill all the way to the top like 3mm connectors do. I think it's OK if they don't. Just so you have a contact patch a little larger than the Cross Section of the wire, it should be fine.
