Is this okay
rchippie
rchippie's Avatar
Is this okay - 01.25.2008, 10:55 PM
Is the gear ratio okay ?. Lehner 1950 8t hi amp with fp lipo's
Differential Ratio: 3.3076923076923075
Transmission Ratio: 1
Other Ratio: 1
Spur Tooth Count: 46
Pinion Tooth Count: 18
Total Voltage: 14.8
Motor KV: 1634
Tire Diameter (inches): 4.43
Tire Ballooning (inches): 0
Motor Current Draw: 60
Motor coil Ω: 0
Spur/Pinion Ratio: 2.56 : 1
Total Ratio: 8.45299 : 1
Tire Circumference (inches): 13.92 inches (353.5mm)
Total Motor Speed: 24183.2 RPM
Vehicle Speed: 37.7 MPH (60.57km/h)
Effective Speed Rate: 2.55mph/V (4.09kmh/V)
Effective KV Value: 1634
Motor Torque: 0.26 ft-lbs
Final Torque: 2.19 ft-lbs
REAL MEN RUN BRUSHLESS
jhautz
jhautz's Avatar
01.25.2008, 11:39 PM
looks great. whats it on? esc? batteries? a little more info would be usefull in an evaluation.
to make it...
or break it...
Silent...But Deadly
01.25.2008, 11:44 PM
I would say 5s would be better, motor speed is a bit low. However if it is in a buggy it should be ok.
rchippie
rchippie's Avatar
01.26.2008, 07:27 PM
LINC
I understand 5s would be better for the 1950 but im not sure 5s would fit under the body. I would rather have a 1940 but i cant find one i can afford .
Jhautz
The esc is a MM the lipo's are flightpower all of this is in my jammin buggy.
01.26.2008, 07:51 PM
I am sure a 5s 4000 pack (or something like that) would fit, but I do not know your intended setup. If you have the motor, esc, battery, etc go ahead. I am sure that it will be fine, you have good equipment there!
rchippie
rchippie's Avatar
01.26.2008, 08:19 PM
I was only asking about the gear ratio i posted for the 1950 8t hi amp.
