Sensor wire extension?
cmcclive
Sensor wire extension? - 06.23.2008, 09:15 AM
Ok, so I have the novak HV system, and an extra half inch or so in the sensor wire length would be great. I would prefer to find an extension cable (instead of splicing and lengthening the wire). Does anyone know where I could find a extender? What about just the male/female connectors?
Thanks for any help
cmcclive
07.12.2008, 09:59 PM
does anyone know where to purchase the male type connector (the plug on the ESC)?
Or does anyone know if the connector has a specific name?
AKA, I want to make (or buy) a short connector for a sensor wire and all I can find are extensions with the female ends. As I cannot unplug my sensor wire from my motor (direct soldered) and I do not want to cut the wires and extend the current sensor (not sure what that would do to the warranty).
Anyone got any ideas or suggestions?
GriffinRU
07.13.2008, 09:59 AM
six position JST ZH connector model number ZHR-6 or equivalent
connector with 6 JST part number SZH-002T-PO.5 26-28 awg contacts or equivalent.
Why you need sensors extention? How long your motors wires?
cmcclive
07.13.2008, 11:47 AM
I find that every now and then when I remove the motor or ESC when I am changing something that I notice I am pulling on the wire alittle. I just though it might be nice to give it a little more slack.
GriffinRU
07.13.2008, 12:05 PM
Novak's part
Team Orion part
Interesting item...
cmcclive
07.13.2008, 01:08 PM
Originally Posted by GriffinRU View Post
After looking into it, the "interesting item" would of had worked. It had both male and female ends. But it is a little costly. Like I previously stated, I found the (hopefully) correct male endso that I can slice into the female/female extension wire I bought.
cmcclive
07.13.2008, 01:00 PM
after a little googling i found that the male end (b 6b-zr) is available from a company in Minnesota with a minimum quantity of 10.
Hopefulyl I ordered the right thing (we will see when they arrive).
07.13.2008, 05:24 PM
Thats the only thing that really annoyed me, having a non-removeable sensor wire sticking out of the motor. Every other company with sensored motors has a plug on the esc, and the motor with a seperate cable.... meh...
tuclai
tuclai's Avatar
08.08.2008, 10:42 AM
CMCCLIVE,
What company in Minnesota has the extension? DO you have the website?
cmcclive
08.11.2008, 10:42 AM
Tuclai,
I appologize if I mispoke, but I did not find a direct extention.
What I did find was the male end connector from:
http://search.digikey.com/scripts/Dk...me=455-1661-ND
It was like $1.90ish for 10 connectors, and $3-4 shipping I think.
I then purchased one of the female/female cables GriffinRU mentioned (either Novak or Orion). Cut it in half and soldered the male connector onto it.
If this seems to complex PM me as I could probably make one up for you inexpensively.
