E-Revo - check your slipper tightness before running
VintageMA
VintageMA's Avatar
E-Revo - check your slipper tightness before running - 06.24.2008, 08:45 PM
Just realized why my motor was running so hot the first time out,
Yes it was party due to being a bit overgeared to start with, but I was changing out the pinion and spur for a better ratio and I realized how loose my slipper was set from the factory.
Make sure to tighten it all the way down and then let it out about 1/2 a turn. The stock setting was almost a full turn out and way to loose - was wondering why I wasn't able to pull any wheelies during the first run.
“Everyone has a right to be stupid; some people just abuse the privilege.”
azjc
06.25.2008, 03:51 AM
I had a similar situation with my BL Revo recently when I was applying WOT and only going about 20mph, during some troubleshooting I placed my foot in front of the front wheels and the motor and spur were turning but that was it, the next morning I checked the slipper and it was nothing my 8mm socket wouldnt cure...
BoilermakerU
06.28.2008, 01:34 PM
Ditto for my Revo 3.3. It was so loose, one of the little pads fell out while I was driving it, doing some major damage to the slipper. Had to replace it after the first day.
Learned my lesson though, so the E-maxx is nice and tight!
tt-01 mamba
07.01.2008, 04:18 PM
Just wondering why a motor would run hotter with a loose slipper??
Isn't it putting less stress on the motor?
VintageMA
VintageMA's Avatar
07.01.2008, 04:36 PM
My only thought is that it is similar to running the motor without being loaded.
david lamontagn
07.01.2008, 05:27 PM
+1
BL_WidePede
07.02.2008, 11:14 AM
No need to back it off. Lock it down...
07.02.2008, 11:18 AM
Unless you jump the truck alot...
Yep, motor heats up more due to lack of load and subsequent high rpms.
Otto
07.02.2008, 06:26 PM
One thing I found out is that the pads on the slipper like to "bed in" first. These slippers seem to like to be overheated and faded a bit once. After that, it grips better and doesn't need the spring to be bottomed out. I run about the same setting - 1/2 turn from compressed, and it works really well.
blueb8llz
07.02.2008, 09:46 PM
but if you slipper is too tight, isnt it harder on your drivetrain? i back my nut out one full turn , is this too loose? when i throttle, there is no slipping at all though.
VintageMA
VintageMA's Avatar
07.02.2008, 10:25 PM
I think every slipper will act a little differently, so no setting will be exactly the same.
When I tightened the slipper after my first run it was out at least a good 2 turns.
I won't be doing too much jumping and I want a little wheelie action, so this setting works well for me.
BL_WidePede
07.02.2008, 10:00 PM
Seems to handle it fine on the E-Revo. What I did after I shelled the first slipper pad is put some medium CA on the back of the pad and let it dry before I put it on. Then put a drop on each peg before installing the pads... Held up so far.
