new castle mamba monster page
Sammus
Sammus's Avatar
new castle mamba monster page - 09.09.2008, 04:41 AM
http://www.castlecreations.com/produ...a_monster.html
It's probably been there for a while now, but I only just noticed it. I was reading through it at found this amusing
It’s always better to simply reduce the heat generated in a system by better engineering than to try and cool things with fans and other gimmicks. Sure a fan can get you a few degrees, but you had better have a superior design to start with.
On the product page of of their only product that comes with a fan attached
Something nice is the pinions:
CC PINION - MOD-1: manufactured from titanium coated hardened steel.
All my RCM and RRP hardened steel pinions got a coating of rust on em pretty quickly, still work fine, but I bet a titanium coated pinion would should look purdy
Gee
A Horse's Ass
Gee's Avatar
09.09.2008, 04:45 AM
Nice catch on the fan quote. Too funny.
Thanks for the answer on the sw ? also.
Dagger Thrasher
I have no idea what's going on
Dagger Thrasher's Avatar
09.09.2008, 05:38 AM
True...but how many monsters so far have thermalled when running without a fan? The Monster already is a good design to start with, but packing that much power handling into an ESC is always going to result in heat...and a fan can't hurt (as long as it doesn't fail!).
I'm really looking forward to their motors; they should be awesome for the price.
DRIFT_BUGGY
DRIFT_BUGGY's Avatar
09.09.2008, 05:53 AM
That wasn't like that yesterday. It says the kits should be out by Christmas and that isn't to far away
Losi 8ight
MMM V1 w/1.20
Airtronics MX3 2.4Ghz
TP 5S 5000mah
Neu 2.5D/F
Sammus
Sammus's Avatar
09.09.2008, 05:55 AM
Lol. Like when the Mamba Max and Mamba Monster were going to enjoy a parallel release - give it a few years :P
sleebus.jones
I like chocolate milk
sleebus.jones's Avatar
09.09.2008, 08:13 AM
2200 KV – Intended for 6S (25.2 Volt) operation. Incredible in monster trucks with up to 6S lipo packs. The 2200 is 75mm long. This is the bad boy!
Maybe it's just me but 6S seems a bit much for a 2200kv? Heck, I've run 1200Kv on 5S A123 (which is probably more like 4S LiPo) and it ran perfectly fine. I'd just rather gear it up.
Sammus
Sammus's Avatar
09.09.2008, 08:20 AM
Not really, 6s lipo on 2200kv is well within its rated maximum rpm, and I think the idea is that at their recommended voltage, gearing and general setup (I think it is safe to say this is offered as an upgrade to the e monsters, which at the moment are the emaxx and erevo), which the average user will be following, the average current draw should be close to peak efficiency of the motor.
Running lower voltage and gearing up you would draw way more current and the motor would be significantly less efficient = more heat.
coolrunnings
09.09.2008, 08:40 AM
2200kv on 6s 55,000 rpm's in a heavy monster truck? Mike tells me for cool running and reliability I should be around 30-35k.
09.09.2008, 09:02 AM
2,200 * 6 * 3.7 = 48 840... High but ok with appropriate gearing...
I'm going to try it on 4s...
2 200 * 4 * 3.7 = 32 560
SpEEdyBL
"Out of spec" enthusiast
SpEEdyBL's Avatar
09.09.2008, 06:00 PM
Hey my novak 4.5 spins at 65,000 rpm and only gets up to 170 w/ no heatsink.
Area 52 Ranch Raceway
T.R.C.R.
MTBikerTim
Yip Yip Yip...
MTBikerTim's Avatar
09.09.2008, 07:40 PM
I am seriously considering sticking the 1515 1y in my buggy just for reliability and low temps. Also the eight race roller comes with a similar length 2100kv so they should be fairly similar power wise.
asheck
09.09.2008, 07:53 PM
Monster’s applications typically pull 4,000-5,000 watts (5 to 6 horsepower) under acceleration.
Thats my favorite part :) let's see 200 amp at 25 v = 5000 watt.
Sammus
Sammus's Avatar
09.09.2008, 09:05 PM
Yeah theres a quote from patrick somewhere (I've had to dig it up a million times for other things in it) that say their test e-maxx was pulling up to 800A for a split second with no probs.
