argggh revo motor heat
e-rev project
argggh revo motor heat - 09.20.2008, 10:46 PM
i finally run my truck for more than a couple min after stripping 4 spur gears (yeah im an idiot and forgot to tighten ALL motor mount screws )
now my motor seems to get hot hot hot (the bad kind) after running 5 min
revo conversion
mmm
medusa 36 60 2000kv
5s1p zippy 5000mah
rcm motor mount
mmm never hits fan temp
batt cool
am i just over geared or under geared, is this too much truck weight for the medusa and hard driving (the only kind of driving for me)
is anyone running this setup successfully?
Differential Ratio: 2.8461538461538463
Transmission Ratio: 2.5
Other Ratio: 1
Spur Tooth Count: 40
Pinion Tooth Count: 18
Total Voltage: 18.5
Motor KV: 2000
Tire Diameter (inches): 5.75
Tire Ballooning (inches): .3
Motor Current Draw: 0
Motor coil Ω: 0.006
Spur/Pinion Ratio: 2.22 : 1
Total Ratio: 15.81197 : 1
Tire Circumference (inches): 19.95 inches (506.71 mm)
Total Motor Speed: 37000 RPM
Vehicle Speed: 44.21 mph (71.01 km/h)
Estimated Adjusted Speed: 42 mph (67 km/h) - 6% loss
Effective KV Value: 2000
KT constant: 0.68 oz-in/A
so very frustrated
09.20.2008, 10:50 PM
IMO, a 60mm long motor is a bit too small for a truck geared for over 40mph. The future 70mm Medusa would be a better choice. But since that is what you have right now, I would reduce gearing to about 35mph, 40 tops. Then, add about 60% (or more) punch control in the ESC. That'll ramp up the acceleration instead of instant on. This will also help temps all the way around. Might also try reducing the timing and start power.
e-rev project
09.20.2008, 10:58 PM
damn i had a gut feeling about that being the answer. What is slated to come out first the 70mm Medusa or castle's new neu type motor.
on the bright side this motor will inspire a new project
thanks
09.20.2008, 11:13 PM
No idea which will be out first. In the meantime, gear down, add punch control, reduce timing, and decrease start power to make things work in the meantime.
e-rev project
09.21.2008, 11:22 PM
awesome thanks for the quick responses
kostaktinos_mt
09.22.2008, 09:30 AM
seems that either something is binding through the drivetrain [badly meshed pinion/spur included], or the motor is deffective/damaged.
the very same motor drived my lgt [12lbs+ rtr, heavier than the revo probably, plus 7inch tires accounted] geared for approximatelly 40mph, and i was getting temps in the region of ~140F at the end of the session [15~20minutes]... the batteries that were used were mostly 14nimh cells and a 5s flightpower pack ocassionally... ambient temps were near 90F [typical summer in greece]...
if your battery and esc temps are low, then gear up and set the timing to about 10degrees...
  Send a message via MSN to kostaktinos_mt
bruce750i
bruce750i's Avatar
09.22.2008, 11:37 AM
Are your motor screws to long and jamming into the windings?
e-rev project
09.22.2008, 02:19 PM
no binding, it rolls pretty easy, good gear mesh. Im pretty sure the screws are not too long, there is no indent or wear marks on the winding inside the screw hole. the total screw length including the hex head is 1/2 inch
so overall length .5" with there being .4" of thread does this sound right for length
09.22.2008, 02:48 PM
The easiest way to gauge screw length is to screw one in gently by hand until it stops (where it touches the coils), then back off a turn. Measure the depth and that's the max you can go. Be sure to do this for all holes and use the smallest value.
e-rev project
09.22.2008, 04:14 PM
to beat a dead horse what is my target motor temps. i searched for a thread i saw awhile back about temps but could not find it sorry for the question that has been answered many times
big greg
09.22.2008, 04:19 PM
stay under 170 for that motor and you will be golden, medusa says anything under 194 is ok
e-rev project
09.22.2008, 11:15 PM
ok the most i hit before i ripped a wheel hex was 165 with a temp gun. but i recorded temps of 65 over an over how do i get accurate readings i was close enough but got different temps the difference was 100 degrees do i sand the shinny motor or paint it white?
and also how do you stop hex ripping i have talons with aluminum hexes i have smaller bolts than stock to hold on the wheels do larger bolts help
love this hobby i only break stuff when i have friends watching
hard to get them addicted
E-Revonut
RC-Monster RC8T
E-Revonut's Avatar
09.22.2008, 11:39 PM
Your best bet is to step up to a 17mm hex, much less likely to have issues
