Gale-Force Ultra GTP
What's_nitro?
Soldermaster Extraordinaire
What's_nitro?'s Avatar
Gale-Force Ultra GTP - 10.12.2008, 01:59 AM
This is just a teaser, but I've thought of resurrecting the EDF-powered GTP in light of this new forum we have here. I think it would be a sweet "Project-X". A lot of you probably remember when I first had the idea. It never really got started because I didn't have the funds to buy what I needed. I still don't and that's why this is a teaser thread. I REALLY WANT TO BUILD IT! I just can't until I have about $2000 in liquid assets. So it may take a while.
Be patient.
TDC57
TDC57's Avatar
10.12.2008, 02:05 AM
shoot us linc, a picture, something... sounds really cool.. I'm looking forward to it..
Nothing!.. Hahahahaaa..
What's_nitro?
10.12.2008, 02:20 AM
http://www.airpowernet.com/twe/produ...roducts_id=558
Now shhhhhhh!
TDC57
TDC57's Avatar
10.12.2008, 02:21 AM
that's TOOOO fricken COOL...
OOOOooo no you got me thinking about the possibilities.. Thank you!!! (your such a giver!)..
10.15.2008, 09:08 AM
Whoa. How do you plan to slow it down? Mech. brakes?
10.15.2008, 10:24 AM
Parachute
TDC57
TDC57's Avatar
10.15.2008, 01:07 PM
Parachute
Liking the sound and the direction of it so far..
TexasSP
Something, anything, nothing
TexasSP's Avatar
10.15.2008, 12:43 PM
Or have a servo actuated deflector like real jets use to slow down. That would be sweet.
www.cubicle101.com
What's_nitro?
10.15.2008, 07:18 PM
Naw, no parachute. Sorry. Definitely mechanical brakes. Though I want to put one on each wheel, if possible. Instead of just one or two on the center dogbones.
cembom
10.15.2008, 07:39 PM
How about all three? That would be sweet. There was a turbine car in rc car action a bit ago I believe. Actually a truck.
MetalMan
MetalMan's Avatar
10.15.2008, 07:57 PM
A cheaper alternative to that combo would be to get the EDF unit alone:
http://www.airpowernet.com/twe/produ...roducts_id=530 (6mm shaft version for KB-45)
Buy a KB-45 XL motor with a kv that will net you a max of about 30,000 RPM with the desired voltage, and buy my HV-110 .
What's_nitro?
10.15.2008, 08:10 PM
The KB-45s get kinda hot don't they? I'm using one for a power drill conversion and it heats up very quickly. I know the high voltage will be better for efficiency, but how much better? Would I still get 10 lbs. of thrust from it?
MetalMan
MetalMan's Avatar
10.16.2008, 12:38 AM
If you're using the KB-45 in a power drill, I'm guessing it is way undergeared (over-revving). Obviously power drills are designed with brushed motors, which are typically much lower powered than a brushless motor of the same size.
If the motor were to hit 30,175 RPM, it should give 12.33lb of thrust as noted on the last link I posted. Thrust should be proportional to RPM.
What's_nitro?
10.16.2008, 01:20 AM
I was thinking about the wasted power versus a more efficient motor. I know it's possible to get the same thrust, but it would use a lot more power since I'd need a higher-Kv motor to make up for the losses.
MetalMan
MetalMan's Avatar
10.16.2008, 01:36 AM
A Neu would definitely be a better non-budget minded motor
