Well I finally put this thing together. I am very happy with the way things have sorted out. At this point I still need to handle the wiring, of the esc ubec receiver and batteries. I'll be using lipo. I hope you like it as much as I do. Your comments questions and recomendations are appreciated. Now if I can just link in a few pictures.
Papa, your truck is by far the nicest ive seen in a while, the way you set it up and put it together, id reccomend you lower it a bit if you are going to race it which i think you are. Edit** i also think you should put the motor in the middle position on the motor mount to distribute weight evenly around the truck, unless your using lipo on the other side?
Losi 8ight e
MMM / Neu 1512 2.5d/f
Thunderpower 5s 5000
I thought about using the middle "high" position on the motor mount. I thought that the weight might put to much stress on the mount and mess with the gear mesh when under stress. I doudled up the bracket on the Side for the same reason. This truck will have lipo in it. However the packs will be the same weight from side to side. With repect to set up. I am hoping that when fully loaded it will settle in. The rear suspension is closer to level as it sits now. My arms are all the way out as it is. I could move the shock upper in to lay them out a bit more. Hopefully the additional battery load will square it away. I still need to adjust camber and toe.
omg...are you serious? i dont beilieve that! Nice e-maxx though. I thought it was a LSP for a second. you hould drive ur e-maxx anyway! put some sand paddlesa and your ready to go.
I guess you have to wait papa. Looks real nice. I like the cf and aluminum look to. Do you have a weight on it yet? I am just curious. :D I thought that is what the body was for. Looks good with the sliver and wing. Let us know how the first run goes.
Peace!
Country
Help support the
Rc-Monster Buy here
