RPM true track pivot balls keep pop out
E-Maxx Sweden
Question RPM true track pivot balls keep pop out - 05.25.2009, 01:21 PM
Need help to solve my problem with the pivot balls keep pop out of my RPM true track.
mkrusedc
NeuMaxx
mkrusedc's Avatar
05.25.2009, 01:54 PM
Sounds like you stripped the arm. I have heard of the pivot ball pulling out of the axle carrier but not the arm. If you stripped I'd get a new arm.
E-Maxx Sweden
05.25.2009, 03:00 PM
Thanks mkrusedc it's the "ball pulling out of the axle carrier", sorry
05.25.2009, 06:42 PM
Yup - Thats why i binned RPM Knuckles!
05.25.2009, 06:58 PM
binned? not following
MetalMan
MetalMan's Avatar
05.25.2009, 07:03 PM
Maybe trash "bin"? Or parts "bin"?
jayjay283
jayjay283's Avatar
05.25.2009, 07:13 PM
http://www.impaktrc.com/product_info...oducts_id=3641
http://www.amainhobbies.com/product_...ducts_id/22519
05.25.2009, 07:48 PM
Just for you...
http://ask.metafilter.com/119596/What-does-binned-mean
nitrostarter
nitrostarter's Avatar
05.26.2009, 09:46 AM
Thats nice, but you're from NJ, most comments in the link are European.
N. Rustler conversion
Rebelgium
05.25.2009, 08:28 PM
Those Tekno axle carriers are the best.
Or you could use a set screw to keep them in, like Mistercrash did on his ERBE.
mkrusedc
NeuMaxx
mkrusedc's Avatar
05.25.2009, 09:31 PM
You can get the Platinum Revo knuckles. The have a retention ring built in to them or you can cut a piece of brass tubing and make a retention ring yourself.
(If this was covered in the links posted above sorry I was lazy and did not feel like checking)
E-Maxx Sweden
05.26.2009, 01:36 AM
Okey but It is the true track RPM (rear) I have problem with, is there a solution for this?
TexasSP
Something, anything, nothing
TexasSP's Avatar
05.26.2009, 09:32 AM
Make your own retention ring from a piece of brass/bronze tubing. A dremel tool and about five minutes should do it.
This is what was suggested in the earlier post by mkrusedc.
www.cubicle101.com
TexasSP
TexasSP's Avatar
05.26.2009, 09:55 AM
He is British though! Like linc but without all the weird cross-dressing stuff.
www.cubicle101.com
nitrostarter
05.26.2009, 09:56 AM
He should have picked up Jersey talk by now...
