Monster maxx esc problem?
luvsrc
RC-MONSTER BRUSHLESS FANATIC
luvsrc's Avatar
Monster maxx esc problem? - 06.28.2009, 08:32 AM
I have 2 monster max esc i have a jammin brushless truggy that has neu 1515 1 y 2200 kv with 5s lipo the first monster esc (has same power settings with the other one) runs like 32mph only and doesnot have much snap off the line cannot lift the front wheels off the ground when you punch the throttle then i installed the other monster esc then with same everything BIG DIFFERENCE it lifts off the front wheels very easily with punching the throttle and truggy has much more power and snap these monster escs are version 2 can i just send my monster esc ( the wearker one to castle) and have them fix? or maybe i'm missing something? thanks for any input!
Brushless Jammin Truggy on NEU 1515 2.5 D on Monster mamba max with maxamps 5000mah 6s Lipo
Gorillamaxx Revo CF version on Mamba maxx ESC with NEU 1515 1Y on Maxamps 4s 8000mah Lipo
bdebde
That's All Folks!
bdebde's Avatar
06.28.2009, 01:53 PM
Be sure all the connections are good. If you send a V2 to Castle, they will likely just replace it with a V3.
E-Revonut
RC-Monster RC8T
E-Revonut's Avatar
06.28.2009, 01:56 PM
What gearing are you running and what batteries? You may be overgeared and your batteries might not be able to supply the current. 5s on a 1515 1Y in a truggy no matter what gearing is going to be a speed machine and require lots of current.
However if everything remains the same except the esc swap it is most likely a bad connection or the esc is somehow gradually dying, although they usually just die!
