Esc misfiring?
brushlessboy16
brushlessboy16's Avatar
Esc misfiring? - 08.28.2009, 04:41 PM
So I have a Mamba monster in a slash with an aveox motor geared for about 40mph on 4s lipo.. really conservative. timing set to 10 .. bear with me as i describe what its doing
You guys know at very low speed how the esc changes switching frequencies,
at the moment the frequency changes my esc loses time with the motor and just sits there and stutters.. if i give it more throttle it just kind of skips over that bit and continues on fine.
I dont think its cogging because the batteries are plenty powerful and it gets better the more I pull the trigger..
What is this and how do i remedy it?
Thanks,
Ben
Foxracin
08.28.2009, 04:44 PM
Do you have the latest firmware on it?
brushlessboy16
08.28.2009, 04:47 PM
shaunjohnson
i pwn nitro
shaunjohnson's Avatar
08.28.2009, 06:06 PM
is the timing ok you reckon?
i never run 10 but this is a diff motor.
  Send a message via MSN to shaunjohnson
brushlessboy16
08.28.2009, 06:20 PM
Seems fine, but i dont know weather to increase or decrease.
Foxracin
08.28.2009, 07:20 PM
Didnt you just get the ESC back from Castle? Did it do it before you sent it in or have you even ran the setup before?
brushlessboy16
08.28.2009, 08:09 PM
it was in a different vehicle before. i dont think it will be that big of a problem. cuz im never really at that low of a throttle input :)
I was just curious.
slimthelineman
slimthelineman's Avatar
08.28.2009, 09:41 PM
my rc8 did this when i changed the timing to 10. temps were higher and power output seemed smoother overall. was running on small indoor clay track and outdoor medium size drytrack when i tested it. both tracks gave similar results. pretty much always run 0 and dont really notice a loss in top speed but the bottom end is snappy and motor is usually 10-20 deg cooler. same gearing and all just changed the timing to see how it worked. runnin a 1512 3d on 4&6s.
slimthelineman
08.28.2009, 09:45 PM
sorry i forgot to add it happened like once in 2-4 packs at each track
Sammus
Sammus's Avatar
08.29.2009, 09:41 AM
isnt that just the nature of sensorless design? all my cars seem to do that from standstill.
brushlessboy16
08.29.2009, 06:51 PM
Mine does it once its moving.
shaunjohnson
i pwn nitro
08.30.2009, 05:55 AM
in the past it was well known but these castle systems have come a hell of a long way...for me it's actually a challenge to make it cogg!!
Sammus
Sammus's Avatar
08.30.2009, 09:31 AM
seriously? I realise theyve come a long way, but in any of my cars if I start on real gentle with the throttle there is always the telltale signs of sensorless motor startup, I think it's unavoidable. I mean, you have to be looking for it, and trying to crawl at a snail pace, but it's there :p I thought that's what the op mightve been referring to.
shaunjohnson
i pwn nitro
08.31.2009, 04:12 AM
nope really dude it is a challenge...i can crawl with my revo if i need to!!
super smooth start up and it honestly IS a challenge for me to get the system to cogg!!
i have figured out how though LOL...there is a procedure!! and even then it's hard!
08.29.2009, 08:06 PM
Weirdness... have you tried altering the throttle dead band setting (wider or narrower) to see if that helps or not?
