I bought this balance connector to charge my two 2s neu packs as one 4s pack . It says it does kokam,neu, & orion. The description says it's a xh plug. But my balance connector for my 4s neu says it's a eh plug . what do you think ?. http://www.amainhobbies.com/product_...=Product-Feeds
He doesn't (I was on the phone with him yesterday), so he's gonna get that board and also a cable specifically for Hyperion. If the board's connector cable won't work, he'll just splice in the Hyperion connector.
Brian of the 3 2s plug sockets . I know the negitive socket has to be with the negitive deans plug . But should i use the middle socket for the positive socket or the one on the right side of the board ?.
I called protek today which is owned by amain hobbies . The tech said there stuff is patterened after hyperion . So it should fit . If not i'll have the hyperion plug as brian mentioned . I also asked about this board doing both xh & eh plug ends . He said it will do both . so im assuming maybe they used a slightly wider plug housing with the correct pin spacing . But im not sure . If it does not work i'll just send it back . Brian what's your opinion on it doing two different plugs ?.
I got my balance plate today . This plate lets me balance multiple packs as a single pack . This plate does the same thing brian's y harness does . This one does both xh & eh plugs . all i did was trim the socket a little so the eh plug would go in eaiser . I will be balancing two 2s packs as a single 4s pack . Also the stock protek plug goes right into my hyperion 610i charger.
