RC8 spur gear question
DwightSchrute
I'm obsessed with The Office
DwightSchrute's Avatar
RC8 spur gear question - 01.23.2010, 12:58 PM
my friend is building a high speed RC8, and i know almost nothing about the buggy. are there any other spurs that can be used on this buggy? i seem to remember someone custom fitting a 36t on the center diff, but i can't remember what company made the spur.
also, does anyone know of a place besides kershaw designs that makes mod
5mm pinions larger than 26T?
any help is greatly, greatly appreciated.
8IGHT 2.0 2650KV MMP
LOSI TEN SCTE NOVAK 3700 MMP
B44 MMP TRINITY D3 6T
B4 MMP TRINITY D3 9.5
E-REVO BRUSHLESS EDITION
B4maz
01.23.2010, 07:42 PM
Try Stock Drive Products. They have many gears with 5mm bores.
The spur gear in a RC8 is a problem. Its difficult to find a custom size. I was lucky in my OFNA GTP. It has a spool (no dif) its just a 8mm shaft. So all I had to do was find a spur gear with a 8mm bore to fit. I wonder if you would be able to fit a OFNA spool on an RC8 so it would be easier to get a small gear on there.
DwightSchrute
01.23.2010, 08:51 PM
thanks for the suggestion. i'm not sure how to put an order together there.i guess i could just bypass the spur and maybe get a large pinion, but do they make mod 1 gears?
phildogg
phildogg's Avatar
01.23.2010, 09:20 PM
I wouldn't deal with Kershaw. here is the store for sdi,just click metric,then gears,spur metal. They have mod1 with 5mm bore. Not sure how many teeth you want.
phil
https://sdp-si.com/eStore/
Slash 4x4 163mph
drc rail 150 mph
phildogg6@yahoo.com
my youtube channel
DwightSchrute
01.23.2010, 09:40 PM
phil
thanks....i think i got it...can you check this out and see if this looks right?
Part Number S10T10M030A0505
Unit Metric
Module ( Pitch) 1
No. Of Teeth 30
Material 2024 Aluminum alloy
Hub Style With Hub & set screw
Quality Class ISO 7 / AGMA 10
Pressure Angle 20°
Bore Size 5.00 mm
Face Width 5.00 mm
Pitch Dia. 30.00 mm
Hub Dia. (0 = Hubless) 10.00 mm
here was the page i got the link from:
https://sdp-si.com/eStore/PartDetail...97&GroupID=591
phildogg
phildogg's Avatar
01.23.2010, 09:46 PM
looks good to me. What material is the spur gear? I heard the alum pinions there weren't the best. To me they should be fine with plastic spur. Also I think the shipping is steep.
Slash 4x4 163mph
drc rail 150 mph
phildogg6@yahoo.com
my youtube channel
DwightSchrute
01.23.2010, 10:17 PM
they make them in aluminum alloy or stainless steel. should i go stainless steel?
Thomas
Thomas's Avatar
01.24.2010, 03:46 PM
Wouldn't it be possible to use the 13/43 diff gears from the TTR S3 to get longer gearing? This should help with top speed.
DwightSchrute
01.24.2010, 03:55 PM
they make 43t gears for it already. i was looking to instead jack the pinion size up considerably...like running a 44t spur or 43/30 or 36t pinion.. i think i'm gonna try this SDPI store and buy a few stainless steel gears and one aluminum just to see how they are. i've always wanted to gear my 8ight that high too, so my friend and i can burn up our esc's together. LOL!.
Thomas
Thomas's Avatar
01.30.2010, 07:48 PM
Originally Posted by DwightSchrute View Post
they make 43t gears for it already. ...
I thought the RC8 was using 10/43 diff gears. So using 13/43 from the S3 would make you some 30% faster.
BTW, you need to change both bevel gears, because the lateral position of the 43T gear changes.
pullinteef
pullinteef's Avatar
01.26.2010, 02:40 AM
kyosho 44T plastic spur fits with slight dremeling to the screw hole line them up better
DwightSchrute
01.26.2010, 08:13 AM
thanks! i'll give it a try!
