Moving from MT to Truggy
crazyjr
crazyjr's Avatar
Moving from MT to Truggy - 04.19.2010, 05:40 PM
I am moving to my truggy from my revo, I am moving the setup from the MT to the truggy. The motor is a 1515/2.5d/f neu motor the esc is a quark 125 w/koolflight UBEC, The plan is for 4-6s lipo use. My only question is, I have a 19 and a 20 tooth pinion at 1.0 mod. Can i run the truggy on the 2.5D with these pinions? Or, would it overheat with that gearing? I know the 2.5D 1515 is a torque monster.
here is the calculator for the 19 pinion At 4s lipo
Differential Ratio: 4.3
Transmission Ratio: 1
Other Ratio: 1
Spur Tooth Count: 48
Pinion Tooth Count: 20
Total Voltage: 14.8
Motor KV: 1650
Tire Diameter (inches): 5.65
Tire Ballooning (inches): 0
Motor Current Draw: 0
Motor Coil Resistance: 0.01
Spur/Pinion Ratio: 2.4 : 1
Total Ratio: 10.32 : 1
Tire Circumference (inches): 17.75 inches (450.85 mm)
Rollout: 1.72:1
Total Motor Speed: 24420 RPM
Vehicle Speed: 39.77 mph (63.89 km/h)
Effective KV Value: 1650
KT constant: 0.82 oz-in/A
dirt101
dirt101's Avatar
04.19.2010, 05:50 PM
I would say thats alittle on the high side for gearing. I would also say 5s would be best for the 2.5d. I had the 2.5d in my CRT on 6s and everytime I actually took it to the track I wished I had 5s instead of 6.
rustler, lx2e, xxt cr
crazyjr
crazyjr's Avatar
04.19.2010, 08:10 PM
I know aboput the 2.5D 1515 on 6s, it's a beast. What it is, is my revo is not holding the power good enough. Every time i run it something happens, This time, it was the pinion on the rear diff (2nd one of the V.1 RC-M 1/8 diff conversions) With Mike not making the diff conversions anymore, I am shelving the revo for a truggy. I am just wondering if i need to buy a smaller pinion, when i get the parts for the conversion. Of course i am going to support the monster for the motor plate, battery box and if need be the pinion.
The truggy will be my Losi 8T (not 2.0)
simplechamp
simplechamp's Avatar
04.19.2010, 08:29 PM
I agree with dirt101. Running 5S would put you right into that 30k RPM sweet spot, and then you could gear down a little bit and still be at 40mph with a lower rollout. On my vehicles I try to keep the rollout no higher than 1.5, and have never had any heat issues when doing so.
crazyjr
crazyjr's Avatar
04.20.2010, 03:11 PM
What exactly is rollout? I seen it shown in BrianG's calculator ( the ratio for 1:1 rollout), but I never really paid attentioin to that. I just geared it till i was comfortable and liked the heat of the motor
E-Revonut
RC-Monster RC8T
E-Revonut's Avatar
04.19.2010, 09:51 PM
I ran that motor in my truggy on 5s with a 15-17t pinion, any more than that and your pushing very high temps, I was about 155-160 at the end of 18 minutes.
