Cogging and flashing yellow LED
CarstenL
Cogging and flashing yellow LED - 03.07.2011, 01:25 PM
My Mamba Monster is acting up, started with cogging and occasional drop in power like power was turned off and on really quick. Now it just has a single yellow LED flashing fast.
I'm thinking it needs to be repaired, or what?
bruce750i
bruce750i's Avatar
03.07.2011, 03:20 PM
Have you Zeroed trims and calibrated TX to MMM?
Maybe remove the switch off of the MMM and twist the wires together, to eliminate any bad switch problems.
CarstenL
03.07.2011, 03:23 PM
Yeas to this first, the second I haven't tried.
It may be a few days before I get around to it. After having two ESC's dump on me over two days, I need some cooling of time so I don't do anything rash.
CarstenL
03.07.2011, 03:30 PM
Tried it without a servo connected with wheels of the ground, it still cogs but the yellow LED doesn't seem to come on anymore.
CarstenL
03.07.2011, 03:45 PM
Hmm come to think of it, i did update the ESC to the latest beta. It didn't do the cogging thing before doing that.
bdebde
That's All Folks!
bdebde's Avatar
03.07.2011, 04:12 PM
I run 1.21 on all my MMM's (latest non beta)... every time I try anything higher that that I have issues.
03.07.2011, 04:17 PM
Wasn't there an issue I read somewhere that if you are on the most recent beta release and reflash down to the older release that was a chance of the MMM smoking? Maybe it was on the Trx forums so I dunno, but something to watch for...
CarstenL
03.08.2011, 05:38 AM
It lives again. Reverted back to v1.21 and everything works just fine. It runs really smooth now.
padrino
hmmm...
03.08.2011, 03:15 PM
I can confirm the same exact behavior with mine.
C-5Quad
03.09.2011, 06:58 PM
Same here I was having the same problem and I went back to 1.21 and she's like butter once again.
THANKS MIKE AND ALL THAT ARE A PART OF THE RC-COLLECTIVE DATA BASE ON HERE
I have learned so much...
03.08.2011, 01:14 PM
Meh, just your standard dodgy firmware version issue
v1.24 is the last 100% solid version- I run that on my V3 MMM, and v1.21 on my old V1 MMM- never any cogging or glitchy throttle issues with either.
