Charging Problem
E-Maxx King
Charging Problem - 11.12.2006, 09:48 PM
I have a duratrax pulse charger and when I charge mt 7 cell IB4200 only one peaks at 8.5 and the other one is at 9.2 and it didnt peak. Whay is this? Do I need a discharger? Like the Deans one.
glassdoctor
TEAM FUSION
glassdoctor's Avatar
11.13.2006, 11:41 AM
A 7 cell pack should peak higher than 8.5v so something smells funny... a good 6 cell pack usually peaks around 9v give or take.
What did the "9.2v" pack peak at? I'd guess 10-10.5v?
The that "peaked" at 8.5 likely just false peaked and there's nothing wrong with it. Was it warm?
I've noticed that brand new IB packs tend to false peak the first couple charges... so if these are new I wouldnt be concerned yet.
coolhandcountry
coolhandcountry's Avatar
11.13.2006, 04:13 PM
First couple charges may work better at a lower amp rating.
Peace!
Country
Help support the
Rc-Monster
Buy here
Serum
Serum's Avatar
11.13.2006, 04:27 PM
First charge new cells with 1/10th c, then discharge them with 1C and easy charge them with 1 C next..
E-Maxx King
11.13.2006, 04:36 PM
I have a duratrax intellipeak so its looked at 3.5a. Its weired I cheacked them before I put them on the charger and they were at 9.1 and 9.2, about five minutes later I cheacked them one says it peaked and it was at 8.6 and the other was at 9.1.
So a discharger would help me? How a deans bulb discharger do?
Also I charged them for like an hour and only one peaked like 15min in? The other didnt peak?
glassdoctor
TEAM FUSION
11.13.2006, 07:57 PM
Something is wrong there... run them dead and try another charge cycle.
If you have a voltmater, check the voltage of each cell... while resting, charging and discharging if possible to look for bad cells or out-of-balance cells.
What you describe doesn't compute... so keep messin with it....
E-Maxx King
11.13.2006, 08:18 PM
well its a stick pack so I cant do that. I dont have a discharger but will this help?
11.13.2006, 08:46 PM
Actually, you can still measure the voltage across each cell. Take the outer heatshrink off insert a thin "electrode" between the cells.
squeeforever
squeeforever's Avatar
11.14.2006, 12:26 AM
Your not supposed to discharge NiMH.
E-Maxx King
11.14.2006, 01:24 AM
why not? What can i do to solve this problem?
