I've bought two 40mm fans, I think they are 12v, as I wasn't wanting to trail around looking for 6v ones and I was buying other things from the same place too (the fans were £2 each anyway).
Is it safe to put them on my main circuit? That would be like 24v on fans, would this noticably reduce power/runtime at all? Would it be best to limit them to 6v each by using a UBEC?
If you have 12V fans and about 24V from the main battery, then yeah... hooking up two fans in series would split the 24V between them.... each gets 12 volts.
12v fans on 6v probably won't push a lot of air.
Jammin CRT MM/Neu 1515 1700kv
Losi 8IGHT MM/Neu 1512 1900kv
Kyosho 777
T4 MM 5700
B4 LRP
XX4 MM 7700
