HV Buggy
macr0w
macr0w's Avatar
HV Buggy - 10.20.2007, 11:51 AM
I am running a Novak HV 6.5 in my E-Maxx. It is fast and has plenty of torque.
I have been considering getting a nitro buggy for some time.
Now that I have been reading some of these brushless buggy threads I started wondering if I could buy a buggy roller and move the HV 6.5 to the buggy.
I always wanted my Maxx to be more of a crawler anyway. If I put the Novak in a buggy then I could set the Maxx up more for crawling.
1.Has anyone ever used an HV system in a buggy?
2.Do you think it will work?
I was almost ready to go nitro but I love the ease and silence of electric. Now after reading about brushless buggies that seems like a better idea.
rschoi_75
Certified Spaceball
rschoi_75's Avatar
10.20.2007, 06:12 PM
1. Yes, it has been done before. Unfortunately I can't give you a referrence off the top of my head, but I am positive you can find one on here.
2. It will work. Heat is the biggest issue. the novak HV systems run very hot, but if you can keep the heat under control, it will work. Most here will suggest a sensorless system... as would I, but if you already have the HV-maxx system, why not?
rcm xt8
rcm xb8
rcm crt.5
macr0w
macr0w's Avatar
11.30.2007, 10:22 PM
I just got me a Mugen Prospec MBX5 roller for a song of fleabay.
I think I'm going to put a pair of Titans back in my E-Maxx and move the HV 6.5 to the new buggy.
Or do you think I would be happier if I bought a Mamba Max and a new can for the buggy?
entjoles
11.30.2007, 10:29 PM
check out novaks web sight, the put a hv4.5 in a buggy and got about 50mph on 4s
i say go for it, should be a great setup and you would only be out the cost of a buggy
starscream
RC-Monster TQ
starscream's Avatar
11.30.2007, 11:56 PM
There won't be a big diff in weight between the EMAXX and a 1/8th buggy so the HVMAXX should work just fine. It seems thermal issues have always plagued the HVMAXX no matter what application. I believe if you disabled the BEC and used a UBEC you may be able to reduce some heat.
I believe Novak has an external capicitor available that should also reduce the HVMAXX's thermal tendencies.
Ha Ha
macr0w
macr0w's Avatar
12.01.2007, 10:14 AM
I don't know about that. My Maxx is a tank coming in at over 12 lbs.
This buggy is a feather weight compared to the Maxx.
Even with a big Li-Po pack it wont weigh 12 lbs.
On another note: Are the RRP pinions that I use on my E-Maxx going to work on the center diff?
rschoi_75
Certified Spaceball
rschoi_75's Avatar
12.01.2007, 12:53 PM
Probably not. Most buggy center diffs are mod 1 pitch. Your emaxx uses 32 pitch.
rcm xt8
rcm xb8
rcm crt.5
starscream
RC-Monster TQ
starscream's Avatar
12.01.2007, 06:39 PM
OK,
I need to clarify as I was referring to a stock emaxx with 4S Lipo ~9+ pounds
If you are running nimh's you'll have one heavy buggy ~10+ pounds.
Ha Ha
macr0w
macr0w's Avatar
12.04.2007, 04:26 PM
This may sound like a dumb question but: Is the electric motor/diff mounts for sale in the shop here reversible? Meaning can they be flipped either direction so the motor can be placed on either side of the vehicle.
I'm talking specifically about the one for the Mugen mbx5. I'm sure it's not, but I can't tell which way it should be turned by looking at the picture.
Thanks,
Serum
Serum's Avatar
12.01.2007, 11:08 AM
these wheels you are using weight a ton.. That would take off 3 lbs with ease..
macr0w
macr0w's Avatar
12.01.2007, 04:58 PM
The E-Maxx is a Monster Truck, not a racer. Stomper Bully.
That's why I prefer spools in the front and rear. This thing is for Stomping and running over stuff. A true basher.
That's all an E-Maxx is good for if you ask me.
My buggy will be for light weight speed.
12.04.2007, 06:16 PM
No it only goes on one side as the bearing fits in it...
If you want some pics of a converted one LMK - I converted my MBX5 buggy/truggy
PICS of build are here:
http://s168.photobucket.com/albums/u180/Arct1k/Mugen/
MetalMan
MetalMan's Avatar
12.04.2007, 07:28 PM
The mounts can sort of be reversed - the motor can sit in the right rear, or at the left front.
12.04.2007, 09:13 PM
I'm not sure - rotating the mount will mean that bearing supporting the diff would now be on the outside of the mount - i.e. nothing stopping is failling out.
Mile also recessed the motor mount screw slot which you would not have...
MetalMan
MetalMan's Avatar
12.04.2007, 09:51 PM
I have drawn up a quick pic. All I did was rotate the mount 180*. The view shown is from above. The top one is with the motor mounted at the right rear. The bottom one is flipped 180*, and has the motor at the front left.
