squeeforever
squeeforever's Avatar
04.25.2007, 05:38 PM
Not sure...I would imagine that there is usually a standard width.
MetalMan
MetalMan's Avatar
04.26.2007, 12:57 AM
Normal 5x11 bearings that are used in our cars/trucks are 4mm thick. The 5x11 bearings that Feigao uses in their motors are 5mm thick.
JOHNNYMAXXIMA
RC-Monster Dual Brushless!
JOHNNYMAXXIMA's Avatar
04.26.2007, 02:30 AM
So would it hurt to use the bearing that is only 4mm thick? Acer e-mailed me back and said that they don't make a 5x11x5.
BP-Revo
BMW M Power!
BP-Revo's Avatar
04.26.2007, 02:34 AM
Well...it probably wouldn't handle as much load, and it would have to be spaced out. Otherwise, I don't see why it wouldn't work.
MetalMan
MetalMan's Avatar
04.26.2007, 10:53 PM
I wouldn't do it... The extra load from the pinion gear can put quite a strain on the bearing. And if you're wanting the bearing to last as long as possible, you'll want one that's the proper size.
JOHNNYMAXXIMA
04.26.2007, 11:14 PM
Well I guess I'm stuck with the stock bearings cause I can't seem to find anyone that makes that size in any type of upgrade. Any suggestions?
MetalMan
MetalMan's Avatar
04.26.2007, 11:17 PM
What about this one I linked to on the first page?:
http://www.offshoreelectrics.com/pro...5c-yzz%235-nb2
It's made for the Feigao motors.
JOHNNYMAXXIMA
04.26.2007, 11:36 PM
Woops, ok, I feel like a dumb a$$. Thanks buddy.
MetalMan
MetalMan's Avatar
04.26.2007, 11:41 PM
We all have our moments :).
