AAngel
04.29.2007, 08:29 PM
Griffin,
What is the result of running two output stages in parallel? Would I get roughly double the voltage and current tolerances? Perhaps I should send you two MMs.
04.29.2007, 08:42 PM
Double the current, same voltage...
BP-Revo
BMW M Power!
BP-Revo's Avatar
04.29.2007, 09:37 PM
Thats the rating...no where in hell will any brushed motor really pull that without turning into a metal glob though. I believe the Novak GTX supports like 760 amps (or so they say...).
GriffinRU
04.29.2007, 11:01 PM
Originally Posted by AAngel
Griffin,
Brian correct I was also thinking about replacing output stage with something more heavy-duty, like Direct-FET or D2-Pak 7...
Custom PCB and hopefully MM can drive them, otherwise custom driver as well, which can be done with ir2101/ir2102 or simular.
04.29.2007, 11:05 PM
lol, pretty much redesigning everything except the brains. If the power board is running at higher voltage, won't the feedback pulses be too high for the controller? Or do you somehow clamp them down?
AAngel
04.29.2007, 11:12 PM
OK, this is getting WAY over my head. All I want (and I don't think I'm asking much) is a controller that will handle up to 6S, though I can live with 5S, and a decent current handling capability that doesn't suffer from heat problems and is smooth at low throttle.
gixxer
gixxer's Avatar
04.29.2007, 11:24 PM
lol, aangel dont worry I think brian and arthur are talking over almost everyones heads.
Kyosho SC, tekin rs, D3 17.5
Hyper 9e, mmp,tekin 1900kv
BP-Revo
BMW M Power!
BP-Revo's Avatar
04.29.2007, 11:30 PM
AAngel, that would be a Quark, besides the heat problem, though that can be cured with the RCM heatsink. It handles 5S (says 6S, but it doesn't really like 6S) and is very smooth.
04.29.2007, 11:34 PM
lol, well given the title of the thread, it was bound to get a little technical. :)
Really, all the good ESC manufacturers should get together and make something that really works well. Castle's programmability and versatility (being able to run brushed/brushless), Quark's smoothness and zero cogging, and MGM's high voltage capability (10s/36 cells!!). Throw in a switching BEC built-in and they could market it as an "All Stars" ESC. And while they're at it, add a port to daisy-chain optional power boards for added current capability. :)
04.29.2007, 11:36 PM
I agree. Aside from the heat and no solid 6s issues, it truly is a winner IMO. I really think that the heat issue has to do with how it is programmed. It is just so much smoother than the MM even though it uses the same FETs and number of them. I think they sacrifice a little efficiency for a better running ESC, but that's just my theory...
crazyjr
crazyjr's Avatar
04.29.2007, 11:47 PM
so long as schultze was not involved (loose connectors) I'd buy it
04.29.2007, 11:48 PM
I specifically left Schulze out of the list. What would be the point of making the ultimate ESC that suddenly bursts into flames? :)
gixxer
gixxer's Avatar
04.30.2007, 12:24 AM
lmao, but yet so true. Right now I would just be happy with 6s and the ease of the MM programming. Anything more then that is just a bonus for me.
jnev
jnev's Avatar
04.30.2007, 12:50 AM
That would really be awesome, and then all the companies can just split the earnings between each other.
AAngel
04.30.2007, 01:00 AM
Yeah, I thought the Quark would be the ticket. I can live with 5S, but when I started reading about the heat problems, I wasn't so sure. I consider excessive heat to be a sign of a bad design, especially in light of the fact that the esc won't do 6S like it's supposed to. I don't mind doing the mod to help keep it cool, but that would render it a one shot deal. If it blows, you're just about screwed.
I figured I'd sacrifice some smoothness for reliability and cool running, so I opted for the 16016 Compro. I bought it almost a month ago and still haven't been able to run it. After a week of trying to program it, I decided that it wasn't me and on Mike's recommendation I sent it to him, so that he could make sure that I wasn't screwing something up. Mike's had it for over a week now, but I haven't heard from him. He must be busy because he hasn't responded to my emails inquiring about it. I'm starting to get the feeling that the Compro is going to have to go back to MGM for repair, which really sucks. This is one of the reasons that I'm going to start ordering everything from my LHS. At least if I get something defective from there, they'll swap it out for me. It's what they've done in the past.
So...I've been running my MM controllers. Apparently, the truck that I'm running is much heavier than most are using the MMs in and the controller is having a hard time. It's a Losi Muggy running big 40 series masher tires and goes about 13lbs with the 8Ah pack. I've blown three MMs running them in the Muggy. Two on 5S and 1 on 4S.
These experiences have lead me to my esc wishlist, which I stated above. I've gotta tell ya, I'm so close to trashing all of this stuff and going to helicopters it isn't funny. By the time I get my Compro back, I won't need the esc as the MMM will probably be out. Either that, or the Teken MT. Geez, I've been whining a lot lately.
What about some sort of a mechanical controller? Like an AC light dimmer switch controlled by a servo. OK, I know I'm reaching now.
As for all of these guys making one good esc, I'd love to see that happen; but you know that it won't. What would be nice is if some new, small, fresh blood firm came about and designed what we were looking for from the ground up.
BTW, has anyone been able to figure out why it is that the Quark won't do 6S?
