Overkill? 30kg/403oz servo -
05.01.2007, 05:29 PM
i need at least 18kg servo for my heavy truck with bigjoes on commandos
I have Proline Steering kit
The new JR looks very good but it might be overkill.
DS8711 ULTRA TORQUE SX
Specs
Type: Digital Ultra Torque
Torque: 347 oz/in @ 4.8V, 403 oz/in @ 6V (30kg@6V)
Speed: .19 sec/60° @ 4.8V, .15 sec/60° @ 6V
Milder version
DS8611A Digital Ultra-Torque MG Servo
Torque: 260 oz/in @ 4.8V, 320 oz/in @ 6V
Speed: .18 sec/60° @ 4.8V, .15 sec/60° @ 6V
Gears: Alloy w/ metal/nylon B1 gear
Or the classic Hitec HS-5955TG
Speed: 0.19 / 0.15 sec @ 60 deg.
English Metric
Torque: 250 / 333 oz.in (4.8v/6v) 18.0 / 24.0 kg.cm
Size: 1.57" x 0.78" x 1.45" 40.00 x 20.00 x 37.00mm
Weight: 2.18oz 62.00g
Weakest and cheapest
Motor Type: Coreless
Bearing Type: Dual Ball Bearing
Speed: 0.24 / 0.19 sec @ 60 deg.
English Metric
Torque: 200 / 250 oz.in (4.8v/6v) 14.4 / 18.0 kg.cm
Or am I just crazy and Futaba S9351 High Torque will do?
FUTM0236
Volts Torque Speed
4.8V 153.0 oz-in. 0.16 sec/60°
6.0V 192.0 oz-in. 0.13 sec/60°
I just cant decide. JR servos are supposed to be one of the best.
Radek
V4 D8 - RX8, XERUN 4168SD
*EX-10 Eurus*
05.01.2007, 05:39 PM
Personally, if money were no object, I'd get the strongest one if you have a high steering load. Also, be aware that the higher torque servos will require more power from your BEC; I wouldn't be surprised if that 403oz-in servo can take 2-3A average with 5-6A peaks.
333oz of power will be enough.
05.01.2007, 05:44 PM
I run a JR Z9000T in my Muggy with 40 series Mashers. My servo puts out around 300 oz/in. or torque. It does the job, although I don't think that a 400 oz/in servo would be overkill. Just make sure that your BEC can keep up with the current draw.
05.01.2007, 06:02 PM
UBEC can handle 3A cont. with 5A peaks. I dropped JR email asking for detailed specs of the DS8711.
Can reciever handle so high current going through?
Radek
*EX-10 Eurus*
05.01.2007, 06:09 PM
It would depend on the thickness of the traces on the PCB, but I would say yes since they are kinda short. I would also keep the servo wire short to reduce resistance since it is pretty small wire.
05.01.2007, 06:29 PM
would it be ok to do connect servo directly to UBEC? (+ and - to UBEC and - and signal to reciever) of course UBEC to reciever as well :)
Radek
*EX-10 Eurus*
05.01.2007, 07:57 PM
There are ubecs that can do more than 3A continuous. They just cost a lot more.
05.01.2007, 08:44 PM
I am quite happy with the Hitec 5955-TG I have in my Revo. It turns the tires with lots of authority. And it helps that I got it brand new for $75 (my employee price is $82).
05.01.2007, 11:02 PM
^^ same here
BMW M Power!
05.02.2007, 12:36 AM
I would have to vote for the 5955TG. I have one in my G2R and its plenty.
Also, even though JR's new servo has a whopping 400oz+ of torque, it has "just" metal gears. In my opinion, once you hit the ~200oz mark, you really need Titanium gears, and thats just what the 5955TG has.
The 5955TG should pretty much outlast your truck.
05.04.2007, 11:00 AM
As I am still bit afraid of Hitec reliability a decided to go for 320oz JR 9000T - all gears metal
the 8611A is AIr version thats why one gear is plastic.
Radek
*EX-10 Eurus*
05.04.2007, 11:25 AM
LOL! I guess this poll was quite useless then.. Look at the results /posts and what you bought.. :)
The hitec has got tough gears.
05.04.2007, 11:58 AM
well the Z9000T has same parameters as HS-5955TG so everyone wins :)
Radek
*EX-10 Eurus*
Linear Mode
