Lehner 2230 11 turn set up
luvsrc
RC-MONSTER BRUSHLESS FANATIC
luvsrc's Avatar
Lehner 2230 11 turn set up - 05.02.2007, 10:21 PM
OK guys will this 1793 rpm/volt Lehner 2230 11 turn be really good set up for 4s or 6s lipo,will this run cooler than the other set ups? Tis is for hard core racing .Will be using MGM and Quark controllers thanks
Brushless Jammin Truggy on NEU 1515 2.5 D on Monster mamba max with maxamps 5000mah 6s Lipo
Gorillamaxx Revo CF version on Mamba maxx ESC with NEU 1515 1Y on Maxamps 4s 8000mah Lipo
pb4ugo
05.03.2007, 12:12 AM
Seems perfect for 5s, that is if you like shredding drivetrains. The Quark doesn't like 6s anyways.
BP-Revo
BMW M Power!
BP-Revo's Avatar
05.03.2007, 12:42 AM
Even for hardcore racing...this is a HELL of a motor...I hope you are running this in a 15 pound truck or something really big and heavy like a Baja 5B.
In the average 10-11lb Maxx or Revo, assuming your drivetrain doesn't explode at the first pull of the trigger, you will probably be fighting to keep all 4 wheels from lighting up.
For racing you want to stick with a 1940 or 1950 - 1950 if you want it to be really powerful, but 1940 is plenty for most applications.
I chose a 1950 because after extensive testing with my truck I have found that it can put stupid amounts of power to the ground without compromising stability, so I decided to opt for the 1950.
Given, this is in a CF G2R setup with dialed in suspension and everything. I spent ~10 runs to get the suspension just right.
luvsrc
luvsrc's Avatar
05.03.2007, 01:27 AM
thanks for the info
