Drill and tap size
cabojoe
Drill and tap size - 05.03.2007, 07:06 PM
What size drill and tap do I use for 3mm machine screws (the screws used throughout the E-Maxx)? I need to tap some holes in an FLM chassis.
Serum
Serum's Avatar
05.03.2007, 07:11 PM
2.5 mm is the standard for M3. if the material is tough, i take a 2.6 drill.
and you need an M3 tap with a .5mm pitch.
HotnCold
HotnCold's Avatar
05.03.2007, 07:25 PM
i use a #39 drill bit and it works great... good luck
Hows that "Hope and Change" working out for Ya???
cabojoe
05.03.2007, 07:43 PM
So I need a 2.5 mm (or #39) drill bit, and a 3mm .5 tap. Thanks guys. :dft003:
HotnCold
HotnCold's Avatar
05.04.2007, 07:06 AM
pro noblem
Serum
Serum's Avatar
05.04.2007, 11:13 AM
Yeah, anytime..
Walter.. You are not complaining about your gasprices, right?! you want to pay what we are paying here? :p
AAngel
05.04.2007, 01:21 PM
Oh, and I'd suggest some sort of lubricant, like tap magic, especially if you're tapping into something kind of hard, like 7075 aluminum.
HotnCold
HotnCold's Avatar
05.04.2007, 05:00 PM
Originally Posted by Serum
Yeah, anytime..
Regardless of what you pay - im still complaining - it stinks that our gas prices skyrocket and then the oil companies post record earnings for the year... OK im done complaining... Thanks for your post serum - i feel better now...
BTW - we - (Mike and I) use boeing lube - its a dry lubricant that works wonders also - and its dry so its not such a pain to get the chips out of the slots on the tap..
Serum
Serum's Avatar
05.04.2007, 05:40 PM
about 8 bucks per gallon to make you even feel better....
(didn't knew you needed this to feel any better walter?)
