Brushless TNX suggestions?
Dagger Thrasher
I have no idea what's going on
Dagger Thrasher's Avatar
Brushless TNX suggestions? - 05.11.2007, 05:47 PM
Hey all,
I was surfing eBay the other day, and long story cut short...I managed to pick up a second-hand TNX 5.2R for £56 including delivery!:027: It's a bit battered and needs some TLC before it can be driven, but most importantly its engine was knackered. So...its obviously calling for a brushless conversion.:018: From what I've seen, not many have done BL TNXs, so it'd be something different and I was wondering if you guys had any suggestions for a power system.
I'd be keeping the stock 2-speed and using the mechanical brakes. I've been thinking something along the lines of a Feigao 7XL with 4S Lipo and an MM/MMM ESC, but what do you guys think would make a good setup? I don't know what my budget would be really, tho nothing too expensive, and I won't be converting it for a few months due to coursework/money, but I just wanna get some ideas in. Here's some pics of the rig as it arrived today:
http://img.photobucket.com/albums/v6...r/HPIM1460.jpg
http://img.photobucket.com/albums/v6...r/HPIM1462.jpg
http://img.photobucket.com/albums/v6...r/HPIM1464.jpg
http://img.photobucket.com/albums/v6...r/HPIM1465.jpg
http://img.photobucket.com/albums/v6...r/HPIM1466.jpg
http://img.photobucket.com/albums/v6...r/HPIM1467.jpg
Thanks for any input guys.:027:
zeropointbug
Z-Pinch racer
zeropointbug's Avatar
05.11.2007, 07:22 PM
Looks good to me, exept that it's dirty, that really bugs me how someone doesn't clean something before they sell it.
Do you know the weight on it? With the wheels/tires on, and everything on it except your BL system (obviously).
Dagger Thrasher
05.11.2007, 07:39 PM
I haven't weighed it as it is, but in stock form with the engine it comes in at 4.2kg...pretty light for it's size! Without the engine and other nitro stuff, I imagine it'd be around 3.7, 3.8kg? The only problem is that the chassis plate isn't very battery-friendly, I need to think hard on how I'll mount the batts.
Don't worry...once my coursework is in, this thing is going to have a TOTAL strip-down, with a thorough clean and replacing/upgrading parts along the way. There's so much mud on it that I can't even reduce the shock preload (the threads are clogged up) lol!
green24
05.11.2007, 09:05 PM
Should be a cool conversion. But what are you going to do about pinion/spur engagement? Isn't the pinion inside the tranny with a dogbone hooked up to the clutch? Also, for battery mounting, maybe you could mount 2 packs next to the dogbone UNDER the chassis, and cut out some of the bottom brace to make it fit. Then make a new brace and skid plate to protect it.
Dagger Thrasher
05.12.2007, 06:38 AM
Are you thinking of the Nitrage? That has the strange dogbone-clutch setup, but the TNX uses a normal spur and pinion...so fitting a motor shouldn't be hard. I'd just need to cut away some of the cover.
As for the batts, thanks for the idea :027: . I see where you're coming from, but in all honesty I wouldn't be too comfortable with mounting LiPos under the chassis.:013: I'll see how much space there is once all the nitro stuff stripped (I can relocate the brake servo), but if needs be I might just design and cut a custom chassis...only if I really need to though, as I'd like to keep this conversion reasonably easy (spent enough time waiting around for custom parts with Cold Fusion!) lol.:018:
captain harlock
RC-Monster Captain
captain harlock's Avatar
05.12.2007, 08:17 AM
I'd recommend a 1950/7 with two Trackpower packs and either a Mamba Max or a Quark to go with the truck. The TNX is as big as a Savage and yet, as light as a feather. With the mentioned setup, you'll be flying.
Nice to meet you!
Dagger Thrasher
05.12.2007, 11:01 AM
Thanks for the suggestion...I'd forgotten about the Trakpowers! They'd be ideal. A Lehner 1950 would be really nice too, but I don't think my student finances could stretch to that so do you think a Wanderer 7XL would work well? I know it's a bit on the hot side, but I don't really want to go above 4S as I might use an MM...and I want to try and keep the truck lightweight. Do you think 45mph would be attainable with this setup?:032: Then again, it'll be interesting to see what motors Castle produce with the MMM.
Incidentally, I think I'll probably use the Revo motor mount Mike has in store; it's much easier than making one and should fit the task perfectly.:027:
zeropointbug
Z-Pinch racer
05.12.2007, 11:28 AM
I think some experienced ppl here are saying an 8XL is just as capable as a 7XL is, just gear up. And it doesn't run as hot, I think I've even heard the 9XL as able as a 7XL. I think 45mph should be farily easily come by, IMO.
I'm thinking a single lipo pack sit behind the tranny width-wise. Maybe grind that engine mount off the chassis.
Who makes the TNX? It kinda looks like Schumacher made to me, with the teeny-weeny turnbuckles on it. :005:
green24
05.12.2007, 12:31 PM
Tamiya makes the TNX.
captain harlock
RC-Monster Captain
05.12.2007, 12:38 PM
How about a Kontronik FUN600-25(2500 RPM)?
They're between a 1940 and a 1930. Very good priced.
Nice to meet you!
Dagger Thrasher
05.12.2007, 06:10 PM
Thanks for the ideas guys! I must admit that I've taken a look at the Kontronik Fun 600 motors, and although I'm sure they perform great, I'm just not very impressed (like the way that the input wires are part of the windings and apparently can't be soldered, etc). How about the Neu 1509/1.5Y? I could probably afford that. Would that be up to the task of pushing the TNX along? Looks to me like it's pretty capable with a 2000W burst output, but you guys have used these motors. The 1512/2D would obviously be more powerful, but is a bit more than I really want to spend.
Sorry to keep asking questions guys, but I just wanna get a feel for what'd be good in this truck. I really appreciate you help.:027:
smhertzog
Breaker of all that is Stock
smhertzog's Avatar
05.13.2007, 05:33 AM
MM has a cogging problem with the 4 pole neu motors. Most people use the quark when they run neus.
Never fight an ugly man..... he has nothing to loose
Serum
Serum's Avatar
05.13.2007, 07:06 AM
And the neu motors have got the wires coming out the very same way like the lehner high-amps and all the other brushless motors. Indeed; the windings are the wires, which is a good thing, lowering the internal resistance of the setup.
However; castle is currently working/testing a software update for this 'issue' they describe it as 'slotted and non slotted motors' This would be an option to choose from in the software. This would address and take care of the neu 'problem' on the MM controllers. I guess the slotted/non slotted means the way the stator is build in the BL motors, while with some motors (neu/plettenberg) you feel serious resistance when you turn the motor, others spin freely (feigao, BK)
The kontronik motors seem to be nice, but i found a nice inrunner of Robbe as well, named Roxy; i saw them on a exhibition in Germany, the person thought they had segmented magnets; their price is unbeatable, they had this massive tall motor, of about 10-15mm taller than the XL can, but it uses a slightly smaller in diameter magnet. (rotor)
captain harlock
RC-Monster Captain
05.13.2007, 07:41 AM
Do you have a link to the Roxy?
Nice to meet you!
Serum
Serum's Avatar
05.13.2007, 09:52 AM
Nope, seems like the robbe website is currently off-line.
I've seen them in person, they come in a somewhat softer shade of green than the mamba motors
