High density Nylon stuff?
High density Nylon stuff? - 05.22.2007, 07:40 PM
Sorry, my brain fell out (again) and I cant seem to find the E-Revo thread where it was mentioned/used to make battery trays. Whats it called again & where can it be bought online? Not for myself but a guy on another forum doing a Revo conversion.
And which Revo conversion thread was it used in again....:007: cursed poor memory.
cemetery gates
05.22.2007, 08:14 PM
Is THIS the one you were talking about?
Bye:018:
*Edit* or was it THIS one? look at post #8
05.22.2007, 08:26 PM
Well done that man! It was the 1st one you found btw, cheers for that.
cemetery gates
05.22.2007, 08:29 PM
No problem! Always glad to help...
Bye:018:
Serum
Serum's Avatar
05.23.2007, 01:31 AM
Life is so simple Neil.. :p
bensf
05.23.2007, 03:30 AM
I was about to post a link to it, but then I realized that you gave me the link. heh. :)
05.23.2007, 10:53 AM
Ah bensf, I see you have joined the darkside.
Here's a link to a an E-revo conversion that uses that UHMW stuff:-
http://www.rc-monster.com/forum/showthread.php?t=3759
I believe that has the dimensions you are after.
bensf
05.23.2007, 11:13 AM
I've been over here for a while, just haven't been posting much.
05.23.2007, 12:06 PM
Fair enough. You'll like it here, everyones so friendly and helpful, and extremely knowledgable.
Finnster
KillaHurtz
Finnster's Avatar
05.24.2007, 11:17 AM
Hey, that thar be me :) I'm using similar stuff on my V2 as I was so satisified w/ it on v1. LMK if you have any ?'s
FYI, I made some errors in the specs on the 1st post, which couldn't edit, so were updated further down.
The density is ~.9g/cc (floats) and is not quite half the weight of CF. However 1/8" material is a bit too flexible to be used as batt trays, 1/4" is much stiffer. IE, you end up with a thicker tray than CF, but about same weight, easy to work with and highly affordable. You could do some stragetic shaving to bring it down, but I never bothered.
I have a 1/8" strip that works extremely well as a roll hoop tho bc of the flexibilty.
