BlackedOutREVO
04.19.2007, 12:01 PM
got a ??
i need 250 bucks spent to do hybrids in my e revo? or what?
skellyo
skellyo's Avatar
04.19.2007, 12:25 PM
Originally Posted by E-MAXX Rock's
got a ??
Yes, $125 per diff/case.
From the description:
"These are sold per unit - 2 required for complete truck."
celticclown
04.19.2007, 06:50 PM
Buggy diffs already sold out. wow.
BlackedOutREVO
04.19.2007, 07:50 PM
OUCH!!!!!!!!!!!! still im spending the money, im not going to screw with stuff that breaks lol
flyers6667
04.26.2007, 07:15 AM
HI
I've received my Hybrid Diff, but the pinion has straight gears, not helical as shown on the pictures.
What about it ?
Is it reliable as the other one ?
Regards.
Patrice
jollyjumper
RC-Monster jumper
jollyjumper's Avatar
04.26.2007, 07:54 AM
both have there cons and pro's, if they are 43/13 those dont exist helical cut i think. but it's not weaker or so, just different.
losi 8ight-t
xray xt8
flyers6667
04.26.2007, 08:03 AM
Merci Jolyjumper :005:
J'espère que le kit sera solide.
I hope the diff kit will be strong enough for my REVO ...I've got a French race this week-end, I hope it will kill some Trucks. :035:
See yaaaa
jollyjumper
RC-Monster jumper
04.26.2007, 08:20 AM
j'espere ton revo marche bien, i hope your revo works well.
hows my french?
alot worse then my dutch i asume.
oh yes, where in france are you?
losi 8ight-t
xray xt8
flyers6667
04.26.2007, 08:22 AM
I'm in the south of France near of Béziers.
I'm going to Besancon this week-end.
Happy to know that there are some europeans here.
Tot ziens :)
RC-Monster Mike
Site Owner
RC-Monster Mike's Avatar
04.26.2007, 10:20 AM
The picture shows the "truggy" ratio, which has a high helical pitch on the ring and pinion gears. The "buggy" diffs also have a slight helical pitch(look close, they do have a slight curve), but it is not nearly as noticeable. You won't likely have any difference in overall reliability - the major difference is in the final drive ratio.
These are tough to keep in stock at the moment - getting and modifying the pinions is proving to be the biggest challenge. I should have the V2 ready in another week, which will accept standard(un modified) diff pinions with custom bearings and will include an 8mm drive cup. The V2 will also accept most 1/8 diffs(kyosho, ofna, Hot Bodies, etc.), so the cases can be sold seperately without the pinions.
These aren't a cheap product to manufacture, either. The shafts are custom made, the cases are of course custom made(and required loads of work to complete), the bearings are custom made(last batch and future batches receive the flanged bearings with a rubber seal on the outside for optimum protection and metal shield on the inside for lowest resistance). Lots of time and work is required to put these together - the good news is that these will likely be the last diff upgrade you need for the Revos(1/8 diff set - $250...finishing the race without blowing your diffs - priceless)!
flyers6667
04.26.2007, 10:56 AM
Thanks mike.
What kind of silicone oil can I put inside ?
30K ? 100K ?
regards.
Patrice
Dafni
Dafni's Avatar
04.26.2007, 11:06 AM
Well, diff oil choice obviously depends on the performance you are looking for.
Try something like 7K/25K/3K (front/center/rear... if you have a centerdiff) and go from there.
SixShooter
04.26.2007, 09:49 PM
Ditto
You may want keep track conditions in mind as well. Now if you're just bashing, go with some thick stuff front and back.
starscream
RC-Monster TQ
starscream's Avatar
06.01.2007, 02:23 PM
Any word on the V2 cases?
Ha Ha
Top Noch Gear
cabking
Top Noch Gear - 06.15.2007, 06:53 AM
I've just finished putting mine together tonight and am so impressed I just had to post something.
The quality is spot on (mine fit together very SNUG), as is the value for money. The machine work that has gone into these diffs is plain to see.......how do you machine a hardened pinon anyway??. :024:
I too needed a couple of shims behind the pinion (the same as any other diff i have owend) and if you love yours as much as i do then a set of helicoils for the case threads is a worth while job.
Excellent work Mike thanks.
I was touting these diffs on another forum, with some Nitro Revo owners. They were all adamant that the stock diffs were up to the job and there was no need for 8th diffs in a Revo............speaks volumes dont you think:005:
