bdebde
That's All Folks!
bdebde's Avatar
06.03.2007, 01:29 AM
Originally Posted by AAngel
I got the name the first time I saw it. I love it.
Also bde happens to be my initials.
Originally Posted by qbayle
I had another question for you I just noticed it looks like there is a mount at the back of the motor as well, is that so the can doesn't move from the tourqe or I think I read something about endbells coming off????
Yeah it clamps the endbell as well as supporting the back off that lloonngg motor.
bdebde
That's All Folks!
bdebde's Avatar
06.09.2007, 08:03 PM
Here is an update with the Lehner 1930/8. It weighed nearly 8 lbs with the XL motor, now it is a little over 7.5 lbs. I lost 5 oz. of motor weight and the RC-Monster heatsink. More on the Lehner later (perhaps another thread).
zeropointbug
Z-Pinch racer
zeropointbug's Avatar
06.09.2007, 10:09 PM
That is one nice system you have there, and who's heatsink is that?
Just a suggestion, what if you moved the MM over a bit more on the one side of the motor, for easier access and cooling?
Also, what BEC is that there? I have never seen that one before.
bdebde
That's All Folks!
bdebde's Avatar
06.09.2007, 10:37 PM
Heatsink is just a cheap Integy clip on.
Didn't want the mamba mounted on the dirt guard, still undecided if I like the arrangement. In fact, I removed the fan I had on it to put it there. I will have to see how hot it will get with this motor (should be less than with the XL).
BEC is Dimension Engineering ParkBEC 6v.
zeropointbug
Z-Pinch racer
06.09.2007, 10:59 PM
ICIC, how many Kv is the motor?
That parkBEC is small, wow. Looks like it at least has some caps on it, some good ones too.
bdebde
That's All Folks!
bdebde's Avatar
06.09.2007, 11:20 PM
Motor is 1930/8, 2613kv
ParkBEC
AAngel
06.10.2007, 01:55 AM
Bruce, I didn't like having the MM on the chassis either. I took some 1/2" aluminum rod and cut them about 1.75" long (or whatever works for you) and then drilled and tapped 5mm holes on one end and 4mm holes on the other. I used the 5mm holes to mount the rods to two of the existing motor mount holes. I then cut a 1/8" thick piece of aluminum plate that would accommodate the MM and punch two holes into it and screwed the plate to the rods and then used some good servo tape to stick the MM to the plate. it all looked like this...
Sorry, but that's the only pic I had of my Turmoil showing the MM mount.
I think that my standoffs were a bit long. You only have to make sure that the plate clears the chassis brace and drive shaft.
bdebde
That's All Folks!
bdebde's Avatar
06.10.2007, 02:17 AM
I even have some of the upper deck stand offs, that should work. Thanks for the idea Tony!
AAngel
06.10.2007, 02:26 AM
Good deal. If it turns out that they aren't long enough and you don't want to or can't work with aluminum rod, you could also use delrin rod. It's really easy to work with and is tough and LIGHT. I order stuff that I need quick from onlinemetals. They aren't the cheapest, but they will cut to order and ship pretty quickly.
bdebde
That's All Folks!
bdebde's Avatar
06.10.2007, 02:31 AM
I got a couple of chunks of AL rod around, but the stand offs would look better IMO.
AAngel
06.10.2007, 03:09 AM
I'm sure they will, since they'll have that factory look to them. I'm just fortunate in that I have some machine equipment left over from my last hobby that survived Katrina. It's nice having a metal lathe. I would have prefered that my lathe had drowned and my mill survived, but I have what I have. LOL.
These days, most things that I make are round.
bdebde
That's All Folks!
bdebde's Avatar
06.10.2007, 01:02 PM
I wish i had machine equipment, a milling machine and lathe would be awesome. I have to rough it, with drill press.
zeropointbug
Z-Pinch racer
06.10.2007, 01:14 PM
Does anyone know of a cheap 'benchtop' CNC machine? That would be perfect for this type of stuff (RC). I would be really interested in checking them out.
bdebde
That's All Folks!
bdebde's Avatar
06.10.2007, 01:16 PM
I have seen them on ebay from time to time.
AAngel
06.10.2007, 03:18 PM
Guys, if you've never done any sort of machine work, you may have the wrong idea about what is needed. I know that CNC is nice, in that you can draw something out and they just feed it into the machine, but I've done lots of work on a cheapie $350, made in China milling machine. Most of what we might do for our own purposes and one shot deals. We might make one or two of them. Most things are so simple to turn out that they don't need drawing up.
I do most of my work on the fly. When I start, I have a pretty good idea of what I need in my head, and I just mount the stock and remove everything that I don't need to be there.
Most of the smaller manual machines are really easy to operate and tooling for them is relatively inexpensive. Go and check out and be sure to also follow the link to minimill.com
You also have to take a look at littlemachineshop.com
My point is this. With what we spend on batteries, speed controllers, and motors, a mill is a small investment. If you are at all mechanically inclined, you should get a mill and just get rolling. I believe people doing this could only promote the hobby. It also gives you a feeling of self satisfaction when you do it yourself.
