Need a new receiver
ncalenda
Need for Speed
ncalenda's Avatar
Need a new receiver - 06.15.2007, 12:29 AM
I have the Futaba 3PM-FM radio and my wire broke on my receiver, so I need a new one.
I currently have the Futaba R153F 3-Channel FM 75MHz, should I just replace it with the same one? Or, is there another one that is a better option.
  Send a message via AIM to ncalenda
silentbob343
06.15.2007, 01:14 AM
resolder the wire.
if it broke at the box and you can't solder close enough, open the box and solder the wire.
You can even buy a new receiver wire if you don't want a soldered wire.
http://www2.towerhobbies.com/cgi-bin...?&I=LXERH8&P=7
ncalenda
Need for Speed
ncalenda's Avatar
06.15.2007, 01:25 AM
Good idea, it ripped off at the top of the Antenna Tube, so I would be able to solder it. Once I solder it, should I shrink wrap it? I lost the part that hangs from the top, so how long of wire should I solder on? I'm assuming a longer wire would be better.
benjakas
06.15.2007, 01:41 AM
No, the longer wire is not better. An antenna has to be in tune with the wavelength of the signal received.
benjakas
06.15.2007, 01:44 AM
Found a wavelength calculator, you can calculate the length of the antenna with http://www.qsl.net/haha/calc.html
ncalenda
Need for Speed
ncalenda's Avatar
06.15.2007, 02:14 AM
I put in 75 Mhz, and it returned 37.44 inches. Does that seem long?
Thanks!!
silentbob343
06.15.2007, 02:37 AM
Thanks!!
Yeah, just make it the stock length which was 19.6 in and put heatshrink over the solder connection.
http://www.futaba-rc.com/radioaccys/futl26.html
Notice that is roughly the same length as the replacement wire I linked to earlier.
Matching the wavelength might be good when you need every last foot, but is most likely overkill for most ground vehicles.
06.15.2007, 02:54 AM
Thanks!!
That's probably for a full wave. You can cut the wire in exactly half for a half wave, and shouldn't have any appreciable loss in signal. Antenna length is most important for a transmitter (could actually damage the RF amplifier), but a receiver is less picky.
silentbob343
06.15.2007, 03:04 AM
I believe you can also do quarter as well. ;)
ncalenda
Need for Speed
ncalenda's Avatar
06.15.2007, 11:48 AM
this helps, thanks everyone. I hope this is why it it glitching, it was running smooth.
