Dafni
Dafni's Avatar
06.16.2007, 05:58 PM
Originally Posted by Serum
What aluminum parts are on it IB?
Sounds like you have a fun job..
Looks like he has the rear uprights and the knuckles. Looks like good cnc stuff.
Serum
Serum's Avatar
06.16.2007, 06:04 PM
Sorry, i meant what brand of aluminum parts are on it.
IBJAMMIN
IBJAMMIN's Avatar
06.16.2007, 06:27 PM
There the Jammin upgrade aluminum part's I got the steering rack and front and rear hubs from www.nitrohouse.com and I found the aluminum ball ends at RC4WD the Titanium turnbuckles are Lunsford. :027:
ID:	3079   Click image for larger version
ID:	3080   Click image for larger version
E-Maxx King
06.16.2007, 11:00 PM
Thats sweet! Can you put some 2.2 wheels on there?
NiCad
R/C Racer
NiCad's Avatar
06.16.2007, 11:40 PM
They are 2.2 wheels. Did you mean something else?
NiCad
Owens Racing™
CRT.5 B/L
Detta ST B/L
RC18(diggity LHO) B/L
Detta Buggies Brushed Bashers
06.16.2007, 11:49 PM
Probably means normal truck wheels. The ones that come with the CRT.5 look more like 2.2" buggy wheels or something. The sidewalls aren't as high nor are the tires as wide as normal 2.2's.
E-Maxx King
06.17.2007, 12:13 AM
Ya put like bow tie t. or something.
Serum
Serum's Avatar
06.17.2007, 03:22 AM
Thanks ibjammin. The steering knuckles are still plastic, correct?
IBJAMMIN
IBJAMMIN's Avatar
06.17.2007, 03:25 AM
The rear 3/16 RC10T&GT wheels bolt right up with a little shorter drive pin on the axel's here's what it look's like with the larger tires compared to the stock tires?
ID:	3082   Click image for larger version
ID:	3083   Click image for larger version
IBJAMMIN
IBJAMMIN's Avatar
06.17.2007, 03:33 AM
Yes the knuckles are stock. :)
Dafni
Dafni's Avatar
06.17.2007, 04:05 AM
Could somebody please post the part number of Proline wheels that would fit this truck and take on regular 2.2 truck tires? (hex or pin does not matter)
Thank you!
Daf
nitro28
06.17.2007, 09:08 AM
Have you ran it with those wheels yet? I am wondering how much hotter the esc and motor will get. When I used that size wheels on my zx-5 buggy the esc got real hot, that is part of the reason I sold it and am looking at a crt.5
skellyo
skellyo's Avatar
06.17.2007, 10:16 AM
Thank you!
Daf
Any RPM or Pro-Line wheels that will fit the front or rear of an electric Rustler/Stampede should work on it since they're 12mm hexes. Any Pro-Line wheels that fit a T3 or T4 with 3/16" axles will fit if you use a shorter drive pin. Here's some options:
For Hexes:
http://www2.towerhobbies.com/cgi-bin...?&I=LXDNC4&P=7
http://www2.towerhobbies.com/cgi-bin...?&I=LXDNC5&P=7
http://www2.towerhobbies.com/cgi-bin...?&I=LXMV44&P=7
http://www2.towerhobbies.com/cgi-bin...?&I=LXMV46&P=7
For Drive Pins:
http://www2.towerhobbies.com/cgi-bin...?&I=LXFDX1&P=7
http://www2.towerhobbies.com/cgi-bin...?&I=LXDW25&P=7
http://www2.towerhobbies.com/cgi-bin...?&I=LX2986&P=7
The difference between the front and rear versions of the RPM wheels will be how far offset they are.
smhertzog
Breaker of all that is Stock
smhertzog's Avatar
06.17.2007, 10:57 AM
If you gear it lower when increasing the size of your tires it should help if not solve the temp increase.:018:
Never fight an ugly man..... he has nothing to loose
nitro28
06.17.2007, 11:20 AM
So what pinion would you suggest for stock wheels and then what size for the bigger wheels?
