G1 Single Motor Mount
G1 Single Motor Mount - 09.03.2007, 11:05 PM
Quick question - Can this be mounted left or right?
I have my motor mounted on the left - The web sight shows right hand mounting.
Thx
GorillaMaxx360
GorillaMaxx360's Avatar
09.04.2007, 10:55 AM
yes it can (i am not 100 percent sure but if it is the one i am thinking of it should be able to do it). give it a try but i am pretty sure it works on either side.
09.04.2007, 02:44 PM
I looked at their site and they are all right mounted - I'm hesitant to blow the cash as the screws are countersunk
09.04.2007, 03:07 PM
Yeah, it looks like it is meant specifically for mounting to one side. I suppose you could counter sink the other side, but that would weaken it. Does it HAVE to be on the other side, or can the other stuff be moved? Or, you could use the stock or optional Traxxas mount and cut off the extra Mickey Mouse ear...
09.04.2007, 03:40 PM
Like this:
Not as pretty, but lighter & much cheaper.
09.04.2007, 05:49 PM
I currently took the dremel to the Emaxx plate but was looking for something slightly cleaner - My hack left a little of the spur gear exposed i.e. if something moves sideways it would hit spur not the blackplate...
ClodMaxx
hold my beer... watch this...
ClodMaxx's Avatar
09.04.2007, 06:56 PM
sheesh, hard to believe my truck was ever this stock, lol. this is an older shot when i first got the G1 motor plate - and i'm confirming what others have already said, but due to the countersunk screw holes it will only mount to the left.
Eflite Blade 400 heli on 3s
09.05.2007, 02:06 PM
Well, you could always just trim off the spare motor mount-ear in a curve, then strip all the anodizing off with 'greased lightning' or something similar, and it will look pretty much the same as the G1 motor mount.
mini-mad
mini-mad's Avatar
09.08.2007, 03:22 AM
yesterday,i've got a stock motor mount,i was thinking about what to do with that and i've found :
i will drill and cut it to do a copy of gorilla's :
there are the two different mounting positions,i've removed the mickey ear but i hate the right side of the plate if anyone have an idea of how to designe it,i'm here
GorillaMaxx360
09.08.2007, 10:44 AM
sorry man, brian was right i did not think when i posted i though you where refering to the old motor mount not the new one.
09.09.2007, 04:22 PM
mini-mad, you mean re-design the area that was been removed to tidy it up? I might have an idea or two if thats what you mean.
mini-mad
mini-mad's Avatar
09.10.2007, 07:10 AM
yes,that's what i mean
09.10.2007, 04:46 PM
I think just removing the material on the outside of the red line will tidy it up alot, and still protect any wires/batteries etc from rubbing against the spur. Once the mount is trimmed to how you like it, strip the anodizing with oven cleaner & then polish it with fine steel wool and wd40 or metal polish if you have some, and it will look just as good as the proper G1 mount.
