VintageMA
VintageMA's Avatar
08.30.2007, 03:29 PM
Good support from Horizon Hobby - they are arranging a RMA for the charger.
“Everyone has a right to be stupid; some people just abuse the privilege.”
jhautz
jhautz's Avatar
08.30.2007, 05:30 PM
Originally Posted by VintageMA View Post
JHAUTZ - I'll post some pics on this thread as I am building. A few questions for you if you've thought out some build issues.
1 - What are you going to be using for the battery mount? This is the one place my customization and craftmanship skills always struggle.
2 - Do you think I should get a UBEC as well for the 4S A123? I was going to try the BEC in the MM - but I know I've read a lot that the MM BEC gets hot even on 3S LiPo.
I typically just use some velocro on the chassis and the pack, then strap it down with a gorilla maxx strap. I havent had any issues with it yet. If it were lipo I would make some sort of box out of Carbon Fiber angle stock or aluminum or plastic to protect the cells more.
Yes, use a UBEC for sure. A cheapo will due just fine for this small truck. Just get a $15 one from one of the flyer websites.
Sorry for the delayed response. I didnt catch that you asked a question at the bottom of the post.
jhautz - What servo are you going to use. I picked up the HiTec HS-5245MG, but I've seen some threads on here about people overheating them with too large tires.
I've always had very good luck with HiTec digital servos, and I am planning on making the jump to 75MHz FM to DSM2 when the Spectrum DX3R radio comes out this fall - so I wanted something solid that I could run at a higher frame rate.
I'm using the same one. Just ordered it a few days ago. Should be here soon. On the plus side the CRT.5 showed up yesterday. (grin)
to make it...
or break it...
Silent...But Deadly
VintageMA
VintageMA's Avatar
08.30.2007, 10:37 PM
The buggy should hopefully arrive tomorrow for the weekend.
I guess I am still missing the UBEC - can you send a link to one?
Any idea what you are going to use for the diff fluid? I've been reading 3K f/3K c/ 1K r is a popular starting point - but I am wondering if it would be better to go go with the standard 3/7/1 used for buggies - I'm never sure where to start with that as I mostly just bash and don't race.
jhautz
jhautz's Avatar
08.30.2007, 10:44 PM
Just look around. there are alot of places that sell em. Mike has a higher end one in his store.
to make it...
or break it...
Silent...But Deadly
VintageMA
VintageMA's Avatar
08.31.2007, 02:40 PM
Just got the CRt.5 in today - WOOHOO!!
Thought this was cool. I ordered it from A Main Hobbies and it came with a 2nd set of wheels :)
Let the fun begin.
08.31.2007, 04:02 PM
Yeah, mine did too. They have different hub mounting so watch out before you glue the tires on there!
jhautz
jhautz's Avatar
08.31.2007, 05:27 PM
Different hub mounting????
What do you mean? I thought it was like the Losi or AE cross pin style.
to make it...
or break it...
Silent...But Deadly
08.31.2007, 06:21 PM
One set is the cross-pin style, the other uses the hex hubs...
VintageMA
VintageMA's Avatar
09.04.2007, 10:44 AM
Yeah - I see that - that's kinda a pain in the butt with different types of wheels - I can't really see using the ones with the cross-pins.
Probably going to put all the nitro stuff that came in the kit up for sale on e-bay (just the muffler piece alone is $50 online) so that'll make up for some of the expense on other parts.
Here's a few pics of what I've done so far. The motor mount isn't great (just some L-arms from Home Depot cut to fit along with velcro tape and velcro straps - but seems to be holding well for some trial runs) - I just don't have the tools or the skilz to do some of the sweet work some of the guys here do.
Buggy seems to be running okay. A few initial thoughts
- the shocks seem very soft, I wonder where I can get some replacements that are a little firmer and the right size.
- I started with a 13T pinion and the motor was running pretty warm but the ESC was cool - I'll try to gear up a little to even that out.
-max Amp draw was recording right about 50A using a 3S lipo pack (still haven't gotten the replacement A123 charger yet)
- I need an antenna mount because it's just hanging loose right now
Pluses - I am very impressed with this buggy for $250. I could easily see this little guy put my LST2 on the shelf for a while.
With Mike's motor mount the whole project was made very easy.
I want to use a plastic spur gear - but I think I'll wait to see if Mike ever has one just for this buggy - I don't want to drill too many holes in the chasis.
ID:	3179   Click image for larger version
ID:	3180   Click image for larger version
VintageMA
VintageMA's Avatar
09.04.2007, 10:48 AM
Oh yeah - one more complaint (or whine) is that with the motor mount and servo setup it is impossible to change a pinion w/o first either removing the servo or removing the whole center diff assembly.
You just can't get to the bottom screw with the servo in the way.
09.04.2007, 12:52 PM
Yeah, that does suck. I thought about making some sort of quick-release for the servo since that would probably be easier to remove quickly than the CD.
VintageMA
VintageMA's Avatar
09.04.2007, 01:14 PM
Just fyi - I meant to say BATTERY mount. Mike's motor mount rocks!
"Here's a few pics of what I've done so far. The motor mount isn't great (just some L-arms from Home Depot cut to fit along with velcro tape and velcro straps - but seems to be holding well for some trial runs) - I just don't have the tools or the skilz to do some of the sweet work some of the guys here do."
jnev
jnev's Avatar
09.04.2007, 07:49 PM
It looks great!! Nice job on it! What Hacker motor are you running in there?
VintageMA
VintageMA's Avatar
09.04.2007, 08:35 PM
Hey, thanks. It is a Hacker B50 8L (3019kv) motor. Very solid, in my opinion not quite worth the money ($180) but I already had the MM esc. I would place it somewhere halfway between a Feiago and a LMT/Neu. Strong power, but you can feel the pull much more when you use a LMT.
Still a lot of tweaking to do........ but that's just part of the fun.
cemetery gates
09.04.2007, 10:34 PM
Looks good! The crt.5 is a great truggy to convert, you will love it.
Its funny how much different my crt.5 looks than others. With the ext. chassis, 1/10 2.2 rims+ tires, full size servo and larger wing+ body its a completely different truggy. I really need to post up a thread of my own, just waiting for the new lipo to arrive (TrueRc 4s 4.2Ah custom pack).
Bye
