Perpetual Motion!
Perpetual Motion! - 09.03.2007, 06:15 PM
I think I've unintentionally discovered a perpetual motion "machine". I was working on my lawn mower and set a screwdriver and rag down on top of my outside A/C unit. A little while later, I noticed that the screwdriver was continually turning all by itself. I thought "Hmmm, that's neat" and forgot about it. Well, a few hours later and it is still turning! I figure I'll attach a small generator and get some free power. : )
Video
Seriously, I'm sure the vibration from the A/C unit has something to do with it, but thought it was kinda neat that it just happened to be postioned perfectly to do this. A little silly, yeah...
sjcrss
Hyper 7 Erevo Center Diff
sjcrss's Avatar
09.03.2007, 06:40 PM
thats pretty cool.....thanks for the vid
Bl E-REVO
Quark 125b
Castle Creations-Neu 2200kv motor
((2s2p)(4s)
7800mah 7.4v Lipo Pack
E-Revo 1/8 scale Hyper 7 CD
http://www.rc-monster.com/forum/show...1&goto=newpost
  Send a message via MSN to sjcrss
09.03.2007, 07:29 PM
Did you bring that screwdriver with you on the mayflower? All kidding aside that is an old screwdriver. I only noticed that cause it looks just like one of my dad's that his dad gave him!!!
09.03.2007, 09:02 PM
lol, I don't even remember where I got that, but I've had it since before I was 16 (and I'm 34 now). It's survived typical screwdriver uses...you know; crowbar, hammer, knife, and rarely even to loosen/tighten screws. : )
I just thought it was really weird that I just threw it on there and it started doing that. I just came back from a 30 mile bikeride (pedalbike) and it was still going strong. I suspect it will last only as long as the A/C is on though...
2FastSS4U
RCM Brushless Savage
2FastSS4U's Avatar
09.03.2007, 09:37 PM
Try to find the frequency that the a/c was vibrating at and then try to replicate it and see if it does that to other objects in a controlled environment.
The wisest mind has something yet to learn. (George Santayana)
09.03.2007, 09:45 PM
At a guess, I would say 60Hz. ; )
Patrick
Patrick's Avatar
09.05.2007, 05:31 AM
How much resistance to stopping does it have?
biddy
09.05.2007, 06:01 AM
its pretty cool but could never be perpetual motion. it only remains spinning like an electric motor due to the induced current from the power transformer.
perpetual motion is the concept of putting in a finite amount of energy, with an infinite output. this is possible if friction was equal to zero, but that could only occur if the spinning object was suspended in a complete vacuum in zero gravity. hence you would need to be in space, 100's of light years away from any planetary bodies to get zero gravity and a vacuum at the same time. i don't think any one will ever get perpetual motion since zero friction is impossible.
glassdoctor
TEAM FUSION
glassdoctor's Avatar
09.05.2007, 07:33 AM
He's just kidding about the pm thing... ; )
Jammin CRT MM/Neu 1515 1700kv
Losi 8IGHT MM/Neu 1512 1900kv
Kyosho 777
T4 MM 5700
B4 LRP
XX4 MM 7700
biddy
09.05.2007, 09:29 AM
yeah i know brianG was kidding, from the posts i had read of his he is too bright for that, but i thought i would post the above and see what reaction i would get : )
some plp where asking what seemed like serious questions about experimenting with it though....
09.05.2007, 09:34 AM
Actually, I don't think the motion is from induced voltage, but rather than the vibration from the unit.
It's been a little on the warm side here the last few days so the A/C unit is still on. And guess what, the screwdriver is still turning away even this morning.
biddy
09.05.2007, 09:42 AM
i would have expected it to have rattled off by now it that case.
best way to tell if its the vibrations is if you replace it with something non-metalic, similar shape and weight...that would be worth a try.
09.05.2007, 09:50 AM
The screwdriver is simply a metal rod. Any induced voltage would be VERY VERY small (in the nano volts), and screwdriver "coil" is oriented the wrong way for an induced voltage to spin it. Also, the A/C case is sheet metal, so that is going to block any magnetic fields from the internal motors.
I don't think I could even try to duplicate it with anything else since this was very random/arbitrary and just happened to do this.
zeropointbug
Z-Pinch racer
zeropointbug's Avatar
09.05.2007, 04:45 PM
Yeah, I have seen stuff like this happen to me lot's too Brian... something about the vibration, just don't know how?
Biddy, you are forgetting 'Zeropoint Energy'.... the amount of energy in empty space (vacuum), which is the entire universe since an atom is made up of almost nothing as well.... anyways, the amount of energy in one cubic cm is 1x10^93 grams of mass energy (e=mc2 energy).......that's big, that's big.
Many labs around the world are reporting phenomena where getting weird readings/input/ouput, and other strange unexplainable things happening.
Is there any reason that this seemingly infinite supply of seething energy cannot be tapped and used? Indeed ask yourself this question, 'what created this universe, energy, consciousness, or both? Energy and consciousness are what this universe is made of, with the grand illusion of seeming solid and materialistic.
If you want to see a really great 'documentary', go and get yourself a copy of 'What the BLEEP, down the rabbit hole.' You will be thoroughly enlightened.
biddy
09.05.2007, 10:26 PM
wow, i had never heard of zero point energy before, just read about it on wikipedia.
it is after all only a theory, but it helps to quantify how electromagnetic fields travel through space. sound waves require the oscillation of particles to propagate, but it seems that electromagnetic waves require some sort of "virtual" vacuum matter to also travel from one place to another. crazy.
