RC-Monster Brushless Heatsink/clamp
Hickoryhead
RC Wanna BE
Hickoryhead's Avatar
RC-Monster Brushless Heatsink/clamp - 09.19.2007, 07:21 AM
Any one know what size I need for a Lehner 1950\7 turn?
bdebde
That's All Folks!
bdebde's Avatar
09.19.2007, 09:36 AM
The clamp part won't fit over the end of a standard lehner. It may on the hi-amp version, you would need the XL.
ClodMaxx
hold my beer... watch this...
ClodMaxx's Avatar
09.19.2007, 02:51 PM
i have a 1940/7 hi amp with a RCM heatsink. i don't have the end clamp, as my heatsink is longer than the motor (i must have the XL heatsink).
i'll measure tonight.
Eflite Blade 400 heli on 3s
skellyo
skellyo's Avatar
09.19.2007, 04:23 PM
Exactly. The aluminum would short out the windings on the motor. Aside from that, the back of a Lehner isn't exactly flat because of the traces, even if you wanted to make a non-conductive clamp piece.
Hickoryhead
RC Wanna BE
09.19.2007, 08:34 PM
I guess I have some engineering issues to work through.
What's_nitro?
Soldermaster Extraordinaire
What's_nitro?'s Avatar
09.19.2007, 09:27 PM
Do you really have to clamp the Lehner's? There isn't any danger of them pulling apart like other motors. If anything I would clamp around the circumference to maximize heat dissipation into the heatsink. Some type of thermal grease would help too, if it isn't there already.
09.19.2007, 10:00 PM
the heatsink was designed specifically for the feigao's, because the end is known to pop off. that won't happen with the lehner, if you want it for looks just leave the clamp part off, otherwise, any heatsink will work really, you'll really have to work to get that lehner hot enough to need a heatsink
Hickoryhead
RC Wanna BE
09.19.2007, 10:04 PM
My main issue is heat. I wanted it for the heat sink. Not the clamp. I will look into using other heat sinks with thermal glue.
pb4ugo
09.20.2007, 12:32 AM
Somebody else is using one with his Lehner by leaving off the back cross piece and using two washers and socket head screws instead to retain and put tension on the rear.
The Lehners won't pop apart easily like a Feigao, but the front has been known to pop off a time or two on some even though they are threaded on.
coolrunnings
09.20.2007, 12:35 AM
Hickery, got any pictures of your truck?
jhautz
jhautz's Avatar
09.20.2007, 03:19 AM
http://www.espritmodel.com/index.asp...OD&ProdID=2077
This heat sink works perfectly on the lehner motors. I'm using one on my 1930 in my LS10. Although, it really doesnt need it. The lehners run cool. If I ever take the motor out for maintenance I'll probably just take the heat sink off and save the weight.
Heres a link to my LS10 thread if you want to see it installed.
http://www.rc-monster.com/tempforum/...highlight=ls10
to make it...
or break it...
Silent...But Deadly
bdebde
That's All Folks!
bdebde's Avatar
09.20.2007, 09:34 AM
My Lehners (1930 and 1940) seem to run about the same temp with or without a heatsink. I probably have enough mass at the motor mount to remove enough heat there.
