crazyjr
crazyjr's Avatar
09.17.2007, 04:45 PM
I hope Mike can have the PowerJazz with the Jazz car software. I will problably send all my Kontroniks to see if they need software update and a few to get fixed.
So they are going to do car software? I been waiting on that
lutach
lutach's Avatar
09.17.2007, 07:41 PM
Mike from Kontronik said it should take 4-6 weeks and that's the last I heard from him. So it is possible if he said that.
crazyjr
crazyjr's Avatar
09.18.2007, 10:55 AM
cool
if they do it Castle will lose big time
othello
HV basher
09.20.2007, 01:59 PM
I just finished a second (and last) video. Those scenes were shot on the same day as the scenes from the first video. This time i was driving on a big open concrete space. So nothing spectacular besides speed passes and a few small drifts. No brushless sound i'm afraid ... Mic was sort of offline, so only music.
video size: 46,6MB, duration: 2:26, windows media 9
click me to watch the video
Here is a still from the video:
enjoy
Hakan_J
09.20.2007, 03:05 PM
Really nice videos!
I really envy that motortemp, thats impressive! Do think its because of the higher voltage? P=Ui.....
09.20.2007, 03:22 PM
Very slick videos. Looks like the jazz controller works well in the vehicle mode. How good are the brakes and does it have a reverse lock out while braking before it goes into reverse? I was going to buy one, but would like some feedback from someone who has experience. Thanks
lutach
lutach's Avatar
09.20.2007, 03:29 PM
Very nice. Man I wish I could find an empty spot like that here in NJ. I will have some competition to show you when I'm done LOL.
othello
HV basher
09.20.2007, 04:28 PM
@hakan_J
Voltage helps a lot with the right motor and gearing. Neu motors really are efficient and with the high voltage i only require between 40-60A to get 1200-1400 Watt to spool up the car to top speed. This motor has an efficiency of >90% and this is within 10-50A. And i use this motor right within its optimum efficiency level. That's why motor temperatures remain that low. On a typical run my average Amp draw is only 10A. That's around 300 Watt average. So the motor really does not break a sweat.
@lincpimp
Brakes are more then sufficient for a buggy. I can lock all 4 wheels when i want to, this is when the car drives above a certain speed. But when rolling slowly the breaks are weak (but i assume that is true for nearly every ESC). You can only go in reverse when the car has nearly stopped or is stopped. So you don't have to apply brakes to go in reverse. And you can't go to reverse when the car is still moving faster then crawling.
@lutach
The spot is sweet but i don't use it often as it is only good for high speed passes (and show off). During winter time this place is used to stock gravel which is used when roads are covered with snow. During summer time many guys use it to testdrive (wheelly) their motorbikes. And a few RC guys know this place also.
I'm looking forward to your project (and competition) and remember i'm only using a 13 tooth pinion. Looking at motor temps there is some headroom to gear it up some more
lutach
lutach's Avatar
09.20.2007, 05:01 PM
@lutach
Here is what I'll be running:
BK 3695
Hacker ION-X motor
10S lipos
I have a solid center with 48T spur and I'll try a 16T just to see what will blow first LOL.
gixxer
gixxer's Avatar
09.20.2007, 05:16 PM
cool videos. its nice how you can see how the watts and temp changes when you are driving.
Kyosho SC, tekin rs, D3 17.5
Hyper 9e, mmp,tekin 1900kv
lutach
lutach's Avatar
09.23.2007, 02:45 PM
othelo,
Here are some pictures of your competition LOL.
ID:	3300   Click image for larger version
ID:	3301   Click image for larger version
othello
HV basher
09.23.2007, 06:59 PM
Looks impressive ... so much batteries
Power will be amazing. Can't wait to see a video of this overpowered buggy and some Eagletree graphs.
Maybe you're aware of this guy @ TrueRC who runs his buggy with 12s lipos and a Neu 1912-1Y. Peaks without limitation @3500W and with between 1800-2000 Watts.
Those power levels are insane for a light buggy. I allready have trouble to get 1200-1600 Watt to the ground without excessive wheel spin.
My main goal with HV was a more efficient setup with temperatures in regions where i do not have to care about them any more. But along with HV also comes power
keep us uptodate with your project
09.23.2007, 07:01 PM
Yes, that does look impressive. Makes me wonder where the servo, receiver, and ESC are gonna go though... Buggy bodies typically don't have much vertical clearance in front which limits placement choices. Truggy bodies have much more room.
lutach
lutach's Avatar
09.23.2007, 07:12 PM
Yes, I'm porra in that forum. I have another XTM that I will probably stuff my 1521 in it LOL. I will definitely keep you guys posted. I will post my pics there as well so he can see it LOL.
lutach
lutach's Avatar
09.23.2007, 07:13 PM
Everything is already laid out. Here is where they will go.
ID:	3303   Click image for larger version
ID:	3304   Click image for larger version
