BitHed
09.27.2007, 11:15 PM
...the chassis is actually quite long...Almost big enough to take a Hellfire stock body...Too long for the E-Sav but probably good for the GP conversion...
...The drivetrain will take what you throw at it for sure...Especially when mated with the GP front and rear diffs...
...You can read ALL about the E-Savage at, surprise surprise, E-Savage.com
EDIT: Here is one shot of the original extended chassis...These are EP diffs front and rear, NOT the GP diffs like the chassis we are talking about...Gives you an idea though...
MTBikerTim
Yip Yip Yip...
MTBikerTim's Avatar
09.28.2007, 02:42 AM
It they only sold battery trays to go with it. The conversion would be so simple.
Bithead. I just saw some pics of your esavage. nice. well i think it was yours.
pullstarter
Pullstarter
09.28.2007, 03:17 AM
I have some battery trays from my Kershaw BL conversion kit, I'd like to get rid of the 2 speed tho its so heavy. Maybe a centre diff setup?
BitHed
09.28.2007, 09:51 PM
...battery trays are too easy...i just use some folded 1mm alloy sheet...plans and everything up at E-Savage.com...I mean the EP crowd has been borrowing ideas from the GP scene (RE: the E-Savage) for ages so maybe its time we paid something back...
MTBTIM:::Thanks mate...You can see my WHOLE gallery with this link...Might be something you like ;)
http://e-savage.com/gallery/showgall...t=500&ppuser=3
rhylsadar
rhylsadar's Avatar
09.29.2007, 10:24 AM
hi
let me see if i got this right. this chassis above will take the normal gp axles of the savage. doing this will bring us in the weight range of the usual gp to ep converted savages, which is about 2-4 pounds more than the e savage.
so then i should put a e savage center gear box in there instead of a modified savage gp center gear box right? this center e savage gear box has plastic gears and is designed to transfer the power of two 550 brushed motors in a light 9 pound e savage. and now it should transfer the power of BL setup for a converted gp savage, that weights about 50% more and is equipped with a big neu and 16 cells or the like?
wouldn't the e savage center gear box then be clearly the weak spot in the whole tranny?
i might be wrong but and one could try it but i would be very positively surprised if this works.
bye
rhylsadar
______________________
Exercitatio artem paravit
rhylsadar at youtube
Serum
Serum's Avatar
09.29.2007, 10:30 AM
Hi Rhylsader;
Jamie designed this chassis so it would accept a good ol' savage front and rear end or the e-savage front/rear end. It only requires a e-savage gearbox. (they are surprisingly beefy btw, they use a 32 pitch gear which is about twice the width of an e-maxx 32p spur.
rhylsadar
rhylsadar's Avatar
09.29.2007, 10:44 AM
hi serum
yeah sounds interesting. i am not worried with the 32pitch but the gears in the box. so anybody already tested an e savage center gear box with a BL set that is common in converted gp savys?
bye
rhylsadar
Serum
Serum's Avatar
09.29.2007, 12:06 PM
Jamie, the owner of fastlanemachine used this with a savage front/rear end and the e-savage gearbox, with a 7XL and 4S lipo. Not the most powerfull setup, but way stronger than the stock dual engine.it held up fine with his
To be honest, i share your idea on the e-savage gearbox.
pullstarter
Pullstarter
09.30.2007, 08:12 AM
E-savage spurs are 32 pitch also?
Serum
Serum's Avatar
09.30.2007, 08:28 AM
yes they are.
pullstarter
Pullstarter
09.30.2007, 08:32 AM
Hmm interesting, sure would make pinions easily available. Anyone seen any e-sav trannies for sale? Be interested to know what they go for :)
BitHed
10.01.2007, 04:05 AM
...Pulley there are a couple of chop-shop sellers on ebay who i know have what you want...Make sure to pull out the plastic shims from INSIDE the diff and replace them with alloy tubing...Let me know if you need them and I will put together a set...You must be outta smokes and gum by now anyway :D
pullstarter
Pullstarter
10.01.2007, 06:01 AM
Woohoo smokes and gum!! I'll cruise the bay and see what i can dig up. I'm off to Hong Kong in a few weeks may see if I can pick up an HV system there
BitHed
10.01.2007, 09:58 AM
..not getting to my end of the street? Oh i forget...That whole hamster thing got you banned from Japan ;)
pullstarter
Pullstarter
10.02.2007, 03:46 AM
I keep telling you they totally distorted the facts and misrepresented the truth in the most horrendous way!!!!!!!!!
It was a gerbal..........................................
