10.28.2007, 09:36 PM
Mike - NP let me know when I can place the order - I'll take it hot off the CNC!
RC-Monster Mike
Site Owner
RC-Monster Mike's Avatar
10.31.2007, 05:59 PM
Roger that - if things go as planned, Thursday or Friday will be the day I prototype the 1st Mugen mount. They should be good to go and listed by Monday on the site. :)
10.31.2007, 11:40 PM
Yay! The new mount you have up looks nice - Will the mugen be the same with an servo & esc/rx mount?
11.02.2007, 01:55 PM
So So close!!!
HummerMan
HummerMan's Avatar
11.02.2007, 05:28 PM
Can't wait to see it!
www.MRPaintin.com
www.RCCNA.com
RC Club of North America
  Send a message via Yahoo to HummerMan Send a message via AIM to HummerMan Send a message via MSN to HummerMan
m_podt
11.03.2007, 06:50 AM
Mike, what kind of diff is required for this mount? The Kyosho diff?
RC-Monster Mike
Site Owner
11.03.2007, 07:54 AM
Ultimately, the mount kit will include a servo tray for sure - the rx mount portion depends on how it all fits. :)
The mount will utilize the stock diff m_podt.
m_podt
11.03.2007, 09:09 AM
But with the Mugen diff you can't use the Kyosho plastic spur. Or isn't that the hot setup anymore?
nl12
nl12's Avatar
11.03.2007, 10:33 AM
you can use a msr spur gear adaptor and a ofna 51 t spur.
RC-Monster Mike
Site Owner
11.03.2007, 11:12 AM
You could implant the entire Hot Bodies LSP center Diff setup(spur and center bulks with the LSP mount) if you wanted, but then you wouldn't need a Mugen mount at all.
The idea is to make a motor mount for the Mugen itself - using the entire Mugen diff and front center bulkkhead with one of our hardened pinions. No need to buy anything else - just the motor mount and hardened pinion. The whole Hot Bodies diff and plastic spur setup is a "work around" when not using a hardened pinion.
The Mugen mount will allow you to use all the Mugen parts instead of transplanting parts from other vehicles. Same idea as all the rest of our mounts. :)
captain harlock
RC-Monster Captain
captain harlock's Avatar
11.03.2007, 01:53 PM
Thanks to my MBX-5R, I guess..;p
Nice to meet you!
11.05.2007, 03:03 PM
Mike - Looking good for today - my F5 key is wearing out and your site sits will be doing very well!
Cheers
11.05.2007, 06:19 PM
Purchased! Another 150 at RCM!
11.10.2007, 09:15 PM
Caution on new mugen mount - A few issues with the mount at the moment on my MBX5T....
1) The lower mount screw holes weren't long enough - Easily enough to recitify with cutting down the screws
2) The holes that the servo mount slots into weren't quite big enough - Easy fixe by enlarging the holes by running a 4.5mm drill bit in for a minute
3) The motor mount adjustment isn't wide enough - The truggy has a 62t spur - I can't get any pinion on... The mount need to be much wider. - Stumped!
I've attached some pics below:
http://s168.photobucket.com/albums/u180/Arct1k/104.jpg
http://i168.photobucket.com/albums/u180/Arct1k/103.jpg
http://i168.photobucket.com/albums/u180/Arct1k/102.jpg
http://i168.photobucket.com/albums/u180/Arct1k/101.jpg
Cheers
Mailman
11.10.2007, 09:40 PM
Cheers
Your spur gear problem is because you have the truggy conversion - not the actual MBX5T. They come with a 46T spur.
