Thread Tools Rating: Thread Rating: 19 votes, 4.37 average. Display Modes
Patrick
Patrick's Avatar
10.29.2007, 11:31 PM
OMG, that poor e-maxx.
Tip-throttle control can keep the car flying with the wheels towards the ground . Poor, poor e-maxx...
mkrusedc
NeuMaxx
mkrusedc's Avatar
10.29.2007, 11:44 PM
I need a ramp to practice.
Not done yet
mkrusedc
NeuMaxx
mkrusedc's Avatar
Not done yet - 11.06.2007, 04:50 PM
I just thought I would update this thread. Some new parts began to arrive today:
FLM extended chassis
FLM shock towers
Later this week:
UE SuperShocks
FLM hybrid bulks
Hot Bodies 1/8 diffs
Still to install:
Strobe slipper
Onfa 51t spur
20t pinion
ESC changes:
Turn on freewheeling
Matbe I'll be done after this...
11.06.2007, 05:20 PM
I think there was a film named after this build.....
"The neverending story"
:D
neweuser
neweuser's Avatar
11.06.2007, 05:30 PM
FLM shock towers
Later this week:
UE SuperShocks
FLM hybrid bulks
Still to install:
Strobe slipper
Onfa 51t spur
20t pinion
ESC changes:
I would think that 20T pinion will run a tad hot with the 1515 1/y. I would go 16T personally.
mkrusedc
NeuMaxx
mkrusedc's Avatar
11.06.2007, 06:47 PM
Maybe but with a 52t mod1 Associated gear and a 17t pinion I have not been above 130 degrees.
neweuser
neweuser's Avatar
11.06.2007, 06:50 PM
Odd....what batts are you running? 52 associated on a strobe???
MetalMan
MetalMan's Avatar
11.06.2007, 07:10 PM
I think he means a MGT 52t spur on the stock slipper clutch.
mkrusedc
NeuMaxx
mkrusedc's Avatar
11.06.2007, 08:02 PM
I have not installed the Strobe yet. MetalMan is correct the 52t is used with stock slipper plates, Associated slipper balls and a heavy duty spring(sprong?) I wasn't sure if that would hold so I got a Strobe with the 51t and a 20t pinion(the 19t were out of stock).
I use two 2s1p TrakPower LiPo batts.
RCShocker
RC Monster
11.07.2007, 11:19 PM
Where did you get your UE shocks, Mark? They were out of stock last time I checked at UE. Your gonna love it even more.
mkrusedc
NeuMaxx
mkrusedc's Avatar
11.08.2007, 02:30 AM
ebay! Had to take a chance. I needed them and UE is out
mkrusedc
NeuMaxx
mkrusedc's Avatar
11.10.2007, 01:33 AM
I got my hybrid bulks and HB diffs. I currently have 3.3 shafts. Do you think I should keep the 3.3 shaft or up grade to CVDs?
The HB diff fit perfect in the bulk. It looks like no shimming required. It would be so easy to just shim the pinion, lube and then bolt it together. A cvd upgrade would also end my shock rubbing problem.
On the other hand the 3.3 shafts are inexpensive, light weight and allow for a little give in my drive train. I would have to take the diff apart to put in the 3.3 output shafts and change out my shocks.
So what would you all advise?
GorillaMaxx360
GorillaMaxx360's Avatar
11.10.2007, 10:33 AM
if you want 3.3 CVDS that work with your vehicle i suggest you give the MIP 3.3 ones a try. The old mip ones have broken for some but the new ones are much beefier than the old ones. I am running hybrids and mips and the same motor combo as you and for the little bit i ran them they held up fine. I personally would stay with the sliders. they are cheaper, just as strong, gives some give(but with the new diffs it is not totally necessary), and they work right now, How ever if the sliders are rubbing and wearing down i would suggest maybe going the CVDS route. If you can get your hands on some UE ones that is the best option.
Serum
Serum's Avatar
11.10.2007, 11:01 AM
If you are looking for a good monster GT spur, i got a white machined one from delrin for about 12 bucks including shipping.
mkrusedc
NeuMaxx
mkrusedc's Avatar
11.10.2007, 11:55 AM
Which size UE will fit my 3.3 E-Maxx?
Tags
e-maxx, flm, mgm, neu, ulimited engineering
