zeropointbug
Z-Pinch racer
zeropointbug's Avatar
11.08.2007, 03:28 AM
the 16018 MGM is the same price as Quark, $275. The MGM can be the better deal in most applications.
Cartwheels
11.08.2007, 03:35 AM
Do you have a fan on Your MM controller. The controller you have should be good with a UBEC. Is cogging a problem or just heat.
Cartwheels
11.08.2007, 03:37 AM
Hey ZP, I was reading your signature. what happens in the year 2012?
david lamontagn
11.08.2007, 09:33 AM
In 2012??? Scientifics says that's the end of the world man
jokerjustin
RC-Monster Cheap Ass
jokerjustin's Avatar
11.08.2007, 11:27 AM
to bad we wont be here anymore we could build a giant rc and fight back against the world!
bdebde
That's All Folks!
bdebde's Avatar
11.08.2007, 04:24 PM
I agree, the MGM runs cool. They are here in the RC-Monster store (not sure if in stock though).
david lamontagn
11.08.2007, 04:56 PM
No i've order the last one yesterday night, but call Mike, he under rate his inventory, and i'am sure that he probably have one or two in stock.
nl12
nl12's Avatar
11.08.2007, 05:20 PM
A neu 1512 or 1509 would probably be quicker, the smaller roter would spool up faster.
bluesilver
11.09.2007, 02:11 AM
From what eveyone is saying the MGMm are the way to go.
I had a look for the 16018 MGM but was unable to find it listed.
Do you have a link for it?
Cartwheels
11.09.2007, 03:32 AM
You linked to it in post #6. It is out of stock at the moment though.
http://www.rc-monster.com/proddetail...MM160183sHCS01
starscream
RC-Monster TQ
starscream's Avatar
11.09.2007, 05:18 AM
Who are Scientifics?
To my knowledge, there will be an alignment of our solar system in the center of the Milkyway Galaxy in 2012. Although, I don't know what affect that will have on anything.
Also, the Inca calander comes to an end in the year 2012. Noone knows exactly why this caladar ends in 2012 (There aren't any Inca's around to ask) but many believe time as we know it will end. There were also many who believed all hell would break loose on Y2K and it turned out to be pretty much an ordinary day...
A couple guys mentioned running the MM with a UBEC to cool things down. I would suggest using a UBEC or CCBEC AND adding an additional cell to run 4S. Of coarse you'll need to gear down accordingly and disable the MM's onboard BEC. The extra voltage should reduce the current enough for you to notice a difference in temps. If not, you can easily add a 5v fan to shave off the remaining excess heat.
There are several guys here that run the MM with NEU motors on 4S & UBEC and have not reported heat issues. I think just changing the ESC is going to be an expensive solution if you plan on continuing to run 3S. I would invest in an extra cell before dropping $300 on a new ESC.
Ha Ha
Happywing
11.09.2007, 08:32 AM
+1. That's my take too. If you plan to put your 1515 in something big eventually, getting an MGM might not be a bad idea. For this situation, the MM can be set up to work great. I use an MM/1515 1.5d/f in my MBX5T and it runs cool. Shouldn't be a problem at all in a Jato.
2FastSS4U
RCM Brushless Savage
2FastSS4U's Avatar
Just wanted to speak up for the quark, I'm running mine on a 13lb. savage with 5s apogee li-mn 5800mAh packs and even when I'm going balls to the walls full throttle it barely even gets warm, though it may be because of the integrated heatsink on my rx/esc tray that mike did for me. It's smooth as silk and stays cool as a cucumber if I'm easy on it.
P.S. Forgot to mention I'm running a 1515/2.5D
The wisest mind has something yet to learn. (George Santayana)
bluesilver
11.09.2007, 05:10 PM
Ok, thans agiain for this info. I am starting to learn a bit more about all of this now.
I guess the question is now, what is a UBEC or CCBEC for the MM ?
I haven't heard of these before, only what peole are telling me.
If this could help me cool things down it would be worth looking into.
Doese anyone have any links to what they are and where to get them form?
I am pretty interesetd to find out more about these.
neweuser
neweuser's Avatar
11.09.2007, 05:20 PM
A UBEC is a Ultimate Battery Eliminating Circuit (i think). A CCBEC is a Castle Creations version? I think that is right.
