brushless b4
elmo_cecil
brushless b4 - 11.08.2007, 08:56 PM
AE RC10 B4RS
stage I
mamba 7700
mamba max esc
3S li-ion
gyro
sway bar
Stage II
alloy front suspension
alloy rear suspension
alloy gear box
Titanium Universal shafts
ST wide wheels all around
dura trax low profile street tires all around
what are you guys suggestions
ID:	3445   Click image for larger version
ID:	3446   Click image for larger version
2FastSS4U
RCM Brushless Savage
2FastSS4U's Avatar
11.08.2007, 09:08 PM
That's hott! I like it a lot, how's the performance with that motor?
The wisest mind has something yet to learn. (George Santayana)
elmo_cecil
11.08.2007, 09:44 PM
performance is insane... 7700 with 9.9v? put a gyro on it to keep it semi straight!!!... some pics of my rc18.. right now running fiego 540 6S 5915kv and waiting for better gearing to come in from an order
ID:	3449   Click image for larger version
ID:	3450   Click image for larger version
sleebus.jones
I like chocolate milk
sleebus.jones's Avatar
11.08.2007, 09:50 PM
I would rig up some skid plates for the top of your shock towers, because I can tell you right now, they won't last a pack's worth of charge. Unless you set your slipper loose, that thing is going to wheelie so fast you won't believe it. I have experience with that same setup, except you are running 2.5v hotter than I was.
I had been intending to make some metal "C" shaped clips to cover the tops of my shock towers so I'd stop wearing them away. Never got around to it though. Nice job on the placement of the cells, good idea to use the size of the body to carry them.
Make sure to take a video of the 1st run, we want to see it while it's in one piece! :)
Sleeb
elmo_cecil
11.08.2007, 10:42 PM
http://s193.photobucket.com/albums/z...t=MVI_2352.flv
http://s193.photobucket.com/albums/z...t=100_0088.flv
http://s193.photobucket.com/albums/z...t=100_0087.flv
but stock tires... ran it once with big tires and had no problems... was geared kinda high though went down two teeth
jnev
jnev's Avatar
11.08.2007, 11:01 PM
Looks good. I bet its wicked fast with that set up to the point its uncontrollable...
elmo_cecil
11.09.2007, 07:35 PM
my mgt i am working on
ID:	3456   Click image for larger version
aqwut
Brushless Heavy Weight....
aqwut's Avatar
11.09.2007, 08:47 PM
are those A123 Cells on the B4?.. they look huge in there...
The Power of BRUSHLESS!!!!!
1HP (electric) = 746 Watts.
Everything is brushless!!
elmo_cecil
11.09.2007, 09:32 PM
dude a123s in each of them.... rc18 uses 2S.... b4 uses 3S and mgt normally runs 6S2P
