Bomb-Proof LSP mount
squeeforever
squeeforever's Avatar
Bomb-Proof LSP mount - 11.13.2007, 02:24 AM
Hey guys, as some of you know, I've had a BPP LSP for a while now, but haven't ran it but a very little since I need to get a center diff mount machined for it. I've been playing around with eMachines Shop and this is what I've come up with. Any comments, suggestions, criticism is welcome. I still need to change it up a little and design the front. I think I might design it to were I can have a top plate to connect them like a standard diff, but its really not necessary. If I do, it'll probably be out of CF. On to the pic...
aqwut
Brushless Heavy Weight....
aqwut's Avatar
11.13.2007, 07:07 AM
wanna sell that BPP LSP Squee?... :) did you design that urself?.
The Power of BRUSHLESS!!!!!
1HP (electric) = 746 Watts.
Everything is brushless!!
squeeforever
11.13.2007, 12:38 PM
Nah, I don't really wanna sell it to be honest. Its not something I can really replace. And its probably the best handling truck I've ever seen. But yea, I designed that mount myself for it. I changed it a little bit more since last night. I dunno if I should make it have a top plate or not....
lutach
lutach's Avatar
11.13.2007, 01:19 PM
That is nice. Here is what I've done so far. It has mount spacing for the 22 and 30 series Lehner motors.
Name:	Motor mount for 22 and 30 series Lehner.jpg
zeropointbug
Z-Pinch racer
zeropointbug's Avatar
11.13.2007, 01:23 PM
Like you would ever need a 30xx Lehner in any kind of R/C truck...
Serum
Serum's Avatar
11.13.2007, 01:24 PM
Yours will be impossible to mill Squee; the straight edges are near impossible
And there isn't much room for the screws to mount it either. Not enough meat.
lutach
lutach's Avatar
11.13.2007, 01:25 PM
Well, I would like to have one LOL. For me the more the better. A 3040 would do just fine. It would make my BPP go .
squeeforever
11.13.2007, 02:06 PM
Mind elaborating? Are you referring to the bottom? If so, I'm gonna add more meat down there, and/or use a top plate as well. It doesn't really look like that now, I'll put up another screen shot tonight.
Serum
Serum's Avatar
11.13.2007, 02:46 PM
If you give me the dimensions, i am more than willing to help you out, and show you what i mean.
The bearing support through hole is too small; It might be hard to get the drive-cups trough. A 1mm smaller hole than the actual bearing hole would be fine.
squeeforever
11.13.2007, 03:12 PM
Ok, thanks Serum! Dimensions don't really matter. Simply a diff mount for a HB diff using a Kyosho spur, with pinions ranging from 9 to 24 (all available mod1) with the standard motor holes and all. The bearing support through hole is 13mm and the other is 16.2 I believe. I figured 1.4mm on both sides was enough, but not to much. The BPP mounts hole is pretty small, but thats a Ofna diff.
Serum
Serum's Avatar
11.13.2007, 03:31 PM
Okay, 16.2 for the bearing is way too large! A 16mm bearing is 15.96 mm od, i thought Mike makes his bearing holes 16.06 or such Hang on, i'll draw you a plate.
zeropointbug
Z-Pinch racer
11.13.2007, 03:52 PM
I usually make bearing holes for bearings that size roughly 0.05mm larger than the bearing OD. Also, I agree, I sometimes make 0.5mm lip for the bearing hole, it's enough, really. About the internal corners, I make mine 3mm diameter, or 1.5m radius fillet.
squeeforever
11.13.2007, 03:56 PM
Alrighty. I've talked to people before about the bearing hole, and thats what I was told, but I'd believe Serum over just about anyone...
Serum
Serum's Avatar
11.13.2007, 04:51 PM
How about something like this?
squeeforever
11.13.2007, 05:03 PM
Should have mentioned the motor has to be in the center. That looks REALLY good though. Think it could be changed just a tad to put the motor over the diff?
