BlackedOutREVO
11.29.2007, 08:34 PM
Looks sweet man! Stinks about the MM, but atleast your getting a new one =)
rchippie
rchippie's Avatar
11.29.2007, 08:52 PM
Thank you for posting the pics & the comment .
REAL MEN RUN BRUSHLESS
ssspconcepts
ssspconcepts's Avatar
12.01.2007, 06:25 PM
Hippie,
You did a great job with you battery tray...you should sell those. I ended up using the Tekno RC Revo battery tray on my CRT.5 EXT Chassis. I got lucky because the bolt pattern matched up perfectly.
Name:	RCM CRT 8.jpg
ID:	3587   Click image for larger version
Name:	RCM CRT 9.jpg
t-maxxracer32
t-maxxracer32's Avatar
12.01.2007, 06:29 PM
that looks extrememly clean sssp very nice work.
gotta love mikes chassis.
12.01.2007, 09:39 PM
hey sssp what tires are those?
glassdoctor
TEAM FUSION
glassdoctor's Avatar
12.01.2007, 09:45 PM
Anyone have a pic with the extended chassis crt.5 next to a 1/10 truck like a T4 or Rustler?
Jammin CRT MM/Neu 1515 1700kv
Losi 8IGHT MM/Neu 1512 1900kv
Kyosho 777
T4 MM 5700
B4 LRP
XX4 MM 7700
ssspconcepts
12.02.2007, 01:00 AM
Thanks but the credit really goes to Mike...I just assembled it.
The tires are Proline 2.2 Dirt Works.
ssspconcepts
12.02.2007, 10:52 AM
Well...this is the best I can do...I don't have any 1/10 scale cars except for my FLM Maxxs. These are the two projects that I am working right now...just need a few more parts to make them run.
So here are a few pics of my Extended Chassis CRT.5 next to my 1/8 CRT Pro. I have also attached a pic of the Ext CRT.5 next to the body I am planning on using...its a 1/10 scale JConcepts Nitro Rustler body (approx 15.75" long). If you are looking to put a body on the EXT CRT.5, try to find one that is about 14.75" to 15" long...this was the best I could do. I would appreciate any info on 15" long bodies if anyone here knows of any....
Name:	RCM CRT 9a.jpg
ID:	3593   Click image for larger version
Name:	RCM CRT 9b.jpg
ID:	3594   Click image for larger version
Name:	RCM CRT 9c.jpg
GO-RIDE.com
12.03.2007, 05:10 PM
Ssspconcepts,
I was thinking of getting one of those Tekno battery boxes for my CRT.5 (RCM ext chassis), but it looks like it sticks out a lot over the edge of the chassis? Does this cause any problems with the body?
Does anyone know if the RCM battery box is narrower than the Tekno?
BlackedOutREVO
12.03.2007, 05:12 PM
Go, No it doesnt, the bodies are wide enough to clear the batt tray
rchippie
rchippie's Avatar
12.03.2007, 06:44 PM
Originally Posted by ssspconcepts View Post
Hippie,
Thank's Your ext.5 looks great . im still using the stock chassis.
entjoles
12.03.2007, 10:32 PM
is that a jconcepts T4 body that you are running on your crt.5??
ssspconcepts
12.03.2007, 10:38 PM
I am also going to use a Rustler Nitro body...it has a slight bulge for the exhaust (where the battery tray now is). I had to order some longer body mounts...took forever to find them but I eventually found some that will work.
ssspconcepts
12.03.2007, 10:42 PM
Your car must FLY! You are running 5000kv right? I just tested mine with the 4500kv neu and 3S...it is-as you said-a fast little sucker!
ssspconcepts
12.03.2007, 10:43 PM
Mine is a Jconcepts Nitro Rustler body.
