Can we get the New Cooling Fan Option on MGM controllers from Mike?
austinmaxx
Can we get the New Cooling Fan Option on MGM controllers from Mike? - 01.10.2008, 05:15 PM
Does anyone know if New Cooling Fan Option on MGM controllers will be available from Mike? ....I will gladly take what I can get, fan or no fan when they come in again though....Fans would be nice
Serum
Serum's Avatar
01.10.2008, 06:02 PM
Sent the man an email!
01.10.2008, 06:30 PM
As an alternative to 5v fans, you could use easy-to-find 12v fans and use a regular cheap LM7812 regulator to bring the voltage down to 12v as long as you are using 4s or thereabouts...
Serum
Serum's Avatar
01.10.2008, 06:33 PM
There goes your efficiency...
wallot
wallot's Avatar
01.10.2008, 07:27 PM
I used to have on my Quark 24V fan that was powered by 16 NiMh cells and speed was about right then after couple rock got into fan I got rid of it and improved passive cooling - FLM chassis is very nice heatsink :)
Radek
V4 D8 - RX8, XERUN 4168SD
*EX-10 Eurus*
01.10.2008, 07:28 PM
Actually, it's not that bad as long as the battery voltage is fairly close to the output voltage and the current is around 100mA (most 40mm fans are around 50mA).
