How Much Over 40,000 Can You Spin a Neu? -
01.11.2008, 02:11 PM
I have a 1515/1y ....how much can you go over the optimum 40,000rpm without overheating/premature wearing?
01.11.2008, 03:15 PM
you be the testdummy..
what is your plan?
a little more input might be handy.
01.11.2008, 04:41 PM
20,000 Rpm more gets you to the rpm limit of the motor, I am sure there is a safety factor built into that so I would go ahead and run 60,000.
01.11.2008, 05:40 PM
Helicopter fliers have tested in their setups that the 1500 series performs optimally between 52k and 56k RPM, assuming you can gear those speeds to something sane.
01.11.2008, 05:49 PM
I run mine at up to 48,000 on a regular basis with no overheating.
01.11.2008, 06:32 PM
I run mine around 40,000+ give or take...no probs, I'm sure it can do a tad more too, but I don't like pushing it to the limit....
01.11.2008, 06:38 PM
Specs on the Neu 15xx Series say 60,000 rpm max
01.11.2008, 07:03 PM
I ran my 1521/1Y with 10S lipos and it was scary at 57000rpm. Blew my rear diff.
Soldermaster Extraordinaire
01.11.2008, 08:46 PM
What controller are you going to use austinmaxx? It had better have a good heatsink. It's gonna get hot real quick at those speeds if it doesn't. If you dont have one yet I'd go with MGM.
01.13.2008, 04:40 PM
60,000 is the max. You will not get any more RPM out of it. If you try, the motor will actually run slower and heat up.
I have seen 3600 watts out of a 1512 (8 second run). I pull the same 3600 watts out of my 1515 but with FAR less heat buildup.
Neus ROCK!
Matt
01.13.2008, 04:45 PM
With 4000+ watts easily attained with the 1521.
01.14.2008, 11:28 AM
I have a MGM 160/18 I will be using, just wanted to know how much I need to hold to the 40,000 rpm sweet spot everyine seems to...I can see you have plenty of wiggle room around the 40,000ish sweet spot thats what I wanted to know ..thnks!
01.14.2008, 11:47 AM
This would depnd on how much voltage your are putting through to the motor. Also gearing and diffs. For example: I run 5s on my 1515 1/y....so that's
18.5 x 2200 (kv) = 40,700 RPM. Now you cn figure in closer using brian's calculator as well with the gearing you have.
Linear Mode
