GriffinRU
01.12.2008, 06:54 PM
Hang about, you did just say that all the MM escs work upto 6s/25v, if you switch off the lipo cutoff (and use a seperate LVC I presume)? Interesting, verrryyyy interesting....
All, the ones which I have...starting from gen1 up to the latest. I have brains from various generations, so I built a simple fixture and tried them all.
No separate LVC, just bench testing with load and receiver pack.
DrKnow65
DrKnow65's Avatar
01.12.2008, 07:04 PM
Thank you Artur, did someone provide a gen3 for you to test?
01.12.2008, 07:22 PM
Sweet. Assuming it all still works fine once the brain is reconnected to the/a powerboard, you would need to use a seperate LVC to protect your lipos (since the built-in one is turned off)? That was what I was getting at before really. You never cease to amaze me with your electrical wizardry....
GriffinRU
Gen3 the one with 30 Fet's, correct?
DrKnow65
DrKnow65's Avatar
01.12.2008, 07:23 PM
Yes, the newest version. Are there more than 3 generations, or less?
GriffinRU
01.12.2008, 07:37 PM
I've seen 4 variations so far...
I've tested 2 modified controllers with 6S for 30 minutes, running up/down/brakes with no problems. Have not tested unmoded ones.
MM mods
ilpufxit
ilpufxit's Avatar
MM mods - 01.12.2008, 08:22 PM
I just sent one of my MM esc's in for mods. I'm hoping to run 5s in a 1/8 buggy when I get it back. Does that seem realistic? Reliable? I'm running it now on 4s with an un-modded MM and so far no problems. I was running an 18t pinion and it got pretty warm after 8-10 min really heavy bashing, didn't thermal though. I switched to 14t and there's very little heat.
DrKnow65
DrKnow65's Avatar
01.12.2008, 08:24 PM
What motor are you running?
Motor
ilpufxit
ilpufxit's Avatar
Motor - 01.12.2008, 08:36 PM
Its a Feigao 8xl. Around 30kv if I'm not mistaken.
GriffinRU
01.12.2008, 08:43 PM
8XL (kv2084) at 5S would be too hot...
Thunderbruiser
Thunderbruiser's Avatar
01.12.2008, 11:55 PM
hey griff i want to look into mods for my mm what does the stg II include? please pm me with details thanks
Caster Racing Team 09'
Sik Wit It Racing Crew Fo life
garage:
E-CRT.5 brushed for now 13x2 orion(tekin g20)2s 5200mah lipo
  Send a message via Yahoo to Thunderbruiser Send a message via AIM to Thunderbruiser
GriffinRU
01.13.2008, 01:38 AM
Mod2 requires two ESC's and as result doubles number of Fets. More Fet's - more Amps.
