Neu Power !!!!!!!!
hootie7159
"1.21 GIGAWATTS!!!"
hootie7159's Avatar
Red face Neu Power !!!!!!!! - 01.17.2008, 05:27 AM
TO MAKE A STORY SHORT....GOT MY TRUE-RC 5S 8000MAH PACK YESTERDAY...RAN MY NEU-EVO FOR 10MIN...HEARD GRINDING SOUND...SAW AN ARRAY OF ORANGE SPARKS...STOMACH DROPPED...TOOK BODY OFF...THIS IS WHAT I FOUND...CHECK OUT THE ATTACHMENTS....HOLY NEU!!! THE DRIVE TRAIN WAS FINE...THE MOTOR WAS FINE (THANK GOD ) BUT THE STEEL MOD-1 ROBINSON RACING SPUR GEAR AND THE MOD-1 16T RC-MONSTER PINION HAD THE TOPS OF THE GEAR TEETH JAGGED/DEFORMED/AND STRIPPED......I GUESS THATS WHAT HAPPENS WHEN THE GEAR MESH IS TOO TIGHT... THE 80A DISCHARGE RATE IS MORE THAN ENOUGH
Losi SCTE
MMP/1410 3800kv
2s 65C 5600mah proteks
Dx3s
01.17.2008, 01:12 PM
sounds insulting, "go eat a pinion"
Serum
Serum's Avatar
01.17.2008, 01:28 PM
stick with plastic spurs, that's my advice..
neweuser
neweuser's Avatar
01.17.2008, 03:05 PM
Plastic is the way to go. Mod 1 is more than enough to handle the power as well.
01.17.2008, 03:19 PM
Two questions:
1: Is that pinion a hardened Mod1 pinion? If not, that's a problem. Mike's hardened pinions are hardened but also have a different tooth geometry to work much better with a steel spur. But, that does look like a hardened pinion, but the pics are a little unclear.
2: On the spur, I see a spot where the tops of the teeth were sheared off. Since it's on one spot, that tells me that the mesh isn't consistent. Possible causes are loose motor mount/motor, or you are getting flexing on the chassis and/or the motor mount.
I've been running steel on steel for a while now and wear is excellent. But proper and consistent mesh is vital for gear longevity.
hootie7159
"1.21 GIGAWATTS!!!"
hootie7159's Avatar
01.17.2008, 06:58 PM
yeah....its the hardened ones...and the wear goes all the way around the whole spur....aw well...i switched the spur to a delrin one and had a couple more mod 1 pinions laying around and now run it meshed correctly with a 36t mod1 spur and a 19t mod1 pinion..... its fast!!!!!!!!!!!
Losi SCTE
MMP/1410 3800kv
Dx3s
ssspconcepts
ssspconcepts's Avatar
01.17.2008, 10:52 PM
Two questions:
That's quite a diagnosis...ever consider a job in the intel field? Imagery analyst all the way
01.18.2008, 04:18 AM
lol. Never considered it, although until I googled it, I had no idea what it was.
neweuser
neweuser's Avatar
01.18.2008, 03:58 PM
Basically you analyze images....seems like it would be kind of fun...
01.18.2008, 04:24 PM
I like my current job better. Probably doesn't pay quite as well as the analyst thingy though...
