ESC Cooling Fans?
JeffEmbracedDC
JeffEmbracedDC's Avatar
ESC Cooling Fans? - 01.17.2008, 08:37 PM
Hey, guys. I have a MM that I need to cool a little bit better. I have a 40mm fan that I can mount via standoffs. but I'd like something that I can mount directly to the heat sink itself. I've seen some that use 20mm fans and run screws in to the heat sink fins but I can't find any 20mm fans. So I guess the question is - where can I find a fan to fit on a MM ESC? Also, I'd like to run it directly off of 4S if possible.
Thanks!
-Jeff
BL 8ight, BL FT B44, BL FT TC4, BL FT T4
  Send a message via Yahoo to JeffEmbracedDC Send a message via AIM to JeffEmbracedDC Send a message via MSN to JeffEmbracedDC
Matthew_Armeni
Matthew_Armeni's Avatar
01.17.2008, 08:40 PM
Well, you'll have to run these off of the rx but that's not a problem.
  Send a message via AIM to Matthew_Armeni
JeffEmbracedDC
01.17.2008, 08:50 PM
Perfect! Thanks!
-Jeff
01.17.2008, 09:25 PM
As an alternative, you could use a 12v fans used for PC chipsets found at most computer stores. Then, use a simple LM7812 regulator off the battery pack. Might be easier to find 12v fans when/if they break or wear out.
TBH, if you're having heat trouble, you are most likely geared too high. Fans mask the problem IMO...
01.17.2008, 10:22 PM
http://cgi.ebay.com/Sunon-25mm-KD050...QQcmdZViewItem
These fit fine on mine - also fit two onto the rcm motor mount
bdebde
That's All Folks!
bdebde's Avatar
I use 25 mm 12v fan directly off of 4s, no problems.
